Knitel's InfinityPump
Started by wizkycho, February 16, 2009, 07:55:05 AM
tbird
hi wiz,
not 100% sure of what you said, but it sounds like you agree.
i'm ready for the next.  what did you have in mind?
tom
It's better to be thought a fool than to open your mouth and prove it!
wizkycho
Quote from: tbird on February 19, 2009, 02:55:34 PM
hi wiz,
tom
to proceed
wiz
brian334
The magic 100 kg. weigh is heavy enough to lift the same water it floats in.
brian334
I suggest this test.
Get yourself a balance, put 100 kg on one side and 1 kg on the other.
Watch what happens.
wizkycho
Hi all !
any idea on how to make this negative preassure for suction smaller...elastic fluid, differently shaped entrance from input pipe
by introducing helium or vacuum to make it able to float with smaller volume...
@tbird
any suggestions, has someone solved it.
pump action part must be made plane...although without seeing actual experiment still can not believe that this preassure just multiplies
and takes over 50kg to start pump action from tube that contains 0.5kg. are there more details on this...
have no time for this exp. we would need obvious method
thx
it was and is interesting
Wiz
