Knitel's InfinityPump
Started by wizkycho, February 16, 2009, 07:55:05 AM
turbo
Your dreams are useless, what we need is proof of concept, repeatable results.
This begins exactly where dreaming ends so maybe it's time for you to wake up  :)
Marco.
wizkycho
thanx to all for proposals on resolving pumping action problem due to hydrostatic paradox
- cappilar action (many capillares could help)
- reshapeing
this pic is another proposal of solving that problem
with two (as I can see it) drawbacks that V2 should be wider
and preassured air inside container allso would enter cilinder
and will make unwanted preassure from bellow on floater
we know much lighter then water and much heavier then air is wide wide range.
can X range fall into that range or is it outside in other or same paradox.
is there a range of X that device now works
I know paradox is strong (by prediction calculus, haven't seen experiment myself to be a believer)
would this help any ?
I'm not very at home with hydrostatic calculus
what do you think or calculate !
wizkycho
Hi all !
My hope is back and my/our device is now more likeliy works over 100%
So All are invited and try to dissmantle it...
I wan't play boogie man and now even if you do.
C'mon and stop it.
Wiz
sushimoto
Quote from: wizkycho on February 20, 2009, 04:30:47 AM
.. You are right, it is becuse i'm trying to make King Hans and his Minions to teach to stop on time and not to make OVERRIDICULOUS every topic they apper in
not just mine, or on the other hand to leave and join another tribe that has less civilized ways. And You may allso as his devoted admierer
(based on who knows what) and lawyer join that tribe and together you'll find the ultimate truth you seek very fast using your very own methods...
do it on yourselves.
Wiz
THATS IT Wiz.
To speak in your words;
You with your minions are a "King of Creativity" and Hans with his minions is a "King of Academics".
So King Hans should help to find what is possible and King Igor should help to figure out what is impossible.
Somewere in beetween is the future of our World containing all the Kingdoms.
I am a Minion of both of you "Kings".  8)
best,
sushi
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
tbird
hi hans,
nice start on your educational material.  will you cover flow relationships?
i think i may have given gravitator some bad info.
question...if you double the diameter of the supply tube (in wiz's 1st design), will the travel time of the piston/weight be  longer, same or shorter?
since your time is limited, a 1 word answer will be fine.
thanks
tom
It's better to be thought a fool than to open your mouth and prove it!
