magnetic proof of concept
Started by Tempest, February 16, 2009, 06:47:33 PM
Tempest
Does anyone know if anyone has tested anything like this? Please use your imagination here to see some ignorance on the linkage aspect. Maybe some linear bearings or some thing. In a pure magnet-linkage setup I think it is best to use weights for testing a concept. It’s pretty hard to refute weights and height for input and output. Pretty simple math that even I can understand. The orange changed to green when I saved to a different format.
hartiberlin
How do you reset it from the second picture back to the first ?
Hugo Chavez
The stick point on these types of mechanisms is unbelievably prohibitive.  One concept that I worked on that used a similar idea which is wheel based around a center crankshaft and metal plates around half the wheel with the other half starting a quarter offset on the opposite side.  The wheel works fantastic until reaching the point of breakaway from the plate.  The other half of the wheel is halfway through the stroke and not enough to break the sticking point.  I think I have a solution but haven't had the money to continue that build(not asking for any either)  Here's where I'm going.  I think with all these concept types, they have the potential to work and the solution I believe is that you must have multiple stages where enough stages are in mid movement to break the sticking point.  So like with my wheel concept the sticking point is only on a few degrees of the 360.  I should be able to add several more wheels at different degrees that are partway through the stroke which add enough force to break the stick point and that so at any one given required breaking of a sticking point the others are in some portion of the stroke.  The same ideology will be required to make your devise work imo.  hope that helps, I'm not an engineer so my description might suck.  Just ask if it didn't make sense and I will explain more.
Tempest
Quote from: hartiberlin on February 16, 2009, 11:33:06 PM
it is not made to be a self runner.
just to see if there is more out then in
so you answer is manuelly
Hugo Chavez
Quote from: Tempest on February 17, 2009, 06:05:38 AM
I'm really not sure of the reason now?  For a non "self runner" One time movement... you get more out than in with a magnet's force drawn to metal.  Why not approach a self running concept?
