magnetic proof of concept
Started by Tempest, February 16, 2009, 06:47:33 PM
Tempest
Quote from: Hugo Chavez on February 17, 2009, 07:44:07 AM
you get more out than in with a magnet's force drawn to metal.  Why not approach a self running concept?
Does it?
If it as been tested then does anyone know how much it can lift vs. how much is needed to move the piece of metal?
If it does move more then it takes to move the metal then it should be easy to make it self run. Use air cylinders to compress air. Use an air cylinder to move the metal plate. You would have to use a tank to store the air and you would have to pre-pressurize to tank to make the metal piece move. Then just watch the air pressure gauge.
Hugo Chavez
Quote from: Tempest on February 17, 2009, 05:45:46 PM
Does it?
It's not easy.  the energy to move the magnet away from the metal is going to bring you back to zero.  That's what the whole game is about, finding a way around what is technically stated as impossible.  check out my first post, I believe it's the only possible solution to a self running concept that uses metal plates and magnets.  The same idea could possibly be incorperated into your design although I like the wheel idea better for its simplicity and the fact that the larger you make the diameter the more wheels can be added to break sticking points.
Tempest
Question still not answered. Anyone else?
Quote from: Tempest on February 18, 2009, 05:25:23 PM
Sure, I'll bite.
It looks like you are claiming that, in the one-shot situation, you will get more work out (weights times heights) than you put in by pulling on the horizontal string.
Fine. One shot. But in that one shot, you are forgetting to compute the work you put into the system setting it up--which is stored as magnetic and gravitational PE and returned as KE, lifting your weights, when you "fire" the system by pulling horizontally.
No overall gain, no free energy proof-of-concept. Sorry.
As to someone having performed the experiment, it seems very similar to some things I've seen on the LaFonte Group threads. No FE there either, in spite of recent claims.
