Thanks to ALL for your help!!
My Current Build
Started by BAHammer, February 23, 2009, 07:13:36 PM
BAHammer
  @ Helmut,
This is what I've been working on.
It's pretty simple. If the starting position ( cg ) of a weight is 85cm's, it can roll out to 1 meter.
A line is attached to the lever the weight is in 75cm's from center.
If the lever drops 20cm's (rotates 15 degrees), the weight's cg will be 96cm's from the center line of the wheel.
This will lift the weight in the lever near bottom center 15cm's. This will be because the line goes under the weight and basically cradles it. When the line is pulled by the dropping lever, the weight can roll against the inside of the lever because the weights are round.
Basically, one weight and lever will perform 2 functions at one time.
I'm not sure when I will be finished with it.
AB Hammer
Jim
That is the best one I have seen you come up with that I have seen. Keep working at it.
With out a dream, there can be no vision.
Alan
brian334
1. On the down side the object must be heavier than the same object on the up side.
2. At the bottom the object must change from being heavier on the down side to being lighter on the up side.
3. On the up side the object must be lighter than the same object was the down side.
4. At the top the object must change back from being lighter on the up side to heavier on the down side.
Very exciting thanks for sharing BAHammer. (are you Ab's evil/good twin? :P)
helmut
@Jim
Good Idea
Quote from: brian334 on February 23, 2009, 08:40:33 PM
If centrifugal force occures, it might be possible to work with same weights.
One must  work with same weights because otherwhise the setup will find its equilibrium very soon.
To shift the weight outside the balance one have to employ a extern force.
A centrifugal force might be such a force.
I guess, that Besseler used the pendulums to store and release these extern forces.
helmut
