First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
neptune
Can anyone please explain what is meant by a 5% salt slution. Does this mean 95 parts water to 5 parts salt. Are these"parts" measured by weight or by volume? Let us not use ambiguous terms that can lead to confusion and misunderstanding. And to failed replications. Also let us all be patient and kind to each other in our efforts.
spacetrax
We should be really thankful to Thomas for his kindness to share his knowledge with us. This is a proof that he loves the world actually, even if he thinks that the world is mean  :)
Danke Thomas!
Tigrotto
@Thomas
Hi Thomas,
I decided to go parallel vith V6 replication and next week together with all our friends, for V14.
Please, replay to me 4 above questions.
Let's summarize them here:
1. The frame is made of "square section rod"? You taked in your document of V6 about 20mmx20mm: looks like a square section!!! Or maybe PIPE (TUBE) of 20mm diameter??? Important or not, please decide and let me know!
2. Definitely: The lowest side of graphite rods are to be 2mm ABOVE the hole of the copper tube, IS THIS TRUE  Thanks for your filling method!
3. You said no words about the DISTANCE between the two plates 25mmx140mm of the capacitor!
Is this 1mm??? Please, confirm!
4. The pyramide lateral surface: ONLY Gypsum-paper boards? Did you tried COPPER or STEEL? It's far much easier to built it in metal!
Beyond these, there are a 5 th important one , you didn't mention :
5. What is the length of the winding coils: diameter 2.5cm, 9 coils, but the total length=???
You can place them very close one to the other or very...large.
We deal with an inductance, depending upon the length of the all 9 coils!!!
I don't want to bother you, but here we are: there are missing informations.
I'm a physicist , an experimentator. when we didn't understand a phenomena, we don't know what are those details to be neglected.
Otherwise, a failure.
This is what i propose to you and to all of our friends:
After I'll receive these 5 answer for which I thank you so much in anticipation,
I'll prepare a checking list containing ALL the informations , but ALL of them you need to replicate V6.
The nice part will come now: I'll prepare a table where we divide these details in : important and ...less important.
An examples:
Quartzsand model: you tried 40 , all of them working , as you said, but none of them not working. This is an example of a detail not very important : the model of quartzsand!
I don't make public this checking list untill I'll not have your supervision and more of this...your approuval, I'm waiting for.
Thanks ,
Dr. Ovidiu (Tigrotto)
neptune
Tigrotto is rightly concerned with what is important and what is not.Do not forget to add to your list the question about how exactly to mix the salt solution, see my post earlier today. Imagine spending much time to build the device and ii fails due to wrong salt solution.
Tigrotto
@ Thomas and all
I prepared the list ( it's basically the english transaltion made by Stefan), where I inserted ALL the comments!
I'm waiting for Thomas approuval to send this to Thomas
Thanks,
Tigrotto
