First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
skywatcher
Quote from: duff on December 11, 2007, 11:28:59 AM
I have had my frame spot welded for a while and have been struggling with the issue of the 3/8" pipe.
I was unable to find 3/8" pipe at a reasonable cost (they wanted $100 for 20' length) and had substituted 3/8 rod instead. Now I think I need to look for  pipe again before I weld this thing up...
That's one of the reasons why i suggested not to hang the converter on this tube, but to put it on a nonconductive rod and mount this to the pyramid base plane, which is much easier. I understood that the 3/8" pipe has no functional meaning and serves only for mounting the converter.
CTG Labs
Quote from: Pegasus on December 11, 2007, 11:27:35 AM
I have conducted  an experiment to see if something happen.
Half glass cup was filled with quartzsand and exposed to the focus of the pyramid for a couple of days.Than I put in the glass some tapwater to make the sand just wet.I inserted the two  graphite electrodes and I connected my meter on voltage reading.The meter jumped at the end of the scale!.But was less 2 Volts....The test was reapeated some time later but this time the meter showd few mV at every reading.Again,after some time the reading turned to zero and not resuscitated..... Is it a real proof od something?.(The wet sand not exposed to the pyramid dont show any voltage.)
Regards,
Cyrano
Hi Cyrano,
If it really only does do this after being placed under the pyramid of course its significant!  You could be showing that this quartz mix is indeed being "charged" by "something/aether" which then allows an electrical reaction.  Then when removed from the pyramid and tested, this charge runs down.  So perhaps keeping it in the pyramid obviously allows this charge to continue!
Great observation, and perhaps validation!
Please try it several more times to confirm!
Dave.
neptune
Magpower, I would say that diagram A is correct even though, according to the TT description, one would expect B to be right. Look at the pyramid on Youtube. Position of the converter looks more like "A".Many people are saying, 180mm from the floor. If this phenomena is real, I strongly suspect the existence of a secret group with V12 plans.If this proves to be the case, and working models result[By Christmas?] I do hope TT lets us less privileged mortals know. Hey wouldn't it be something if one of us guys beat them to it.....
skywatcher
To get meaningful results, i would suggest the following procedure:
Take two identical glass cups, fill them with identical sand, then put one into the pyramid and leave the other one outside the pyramid.
After the waiting time, put the same amount of water into both cups and then measure the voltages.
Additional question:
Did you have the gypsum plates mounted on the frame, or did you use only the frame without gypsum plates ?
skywatcher
Quote from: Pegasus on December 11, 2007, 11:56:48 AM
ANYONE HERE WITH A SCOPE, CAN TAKE SOME PICS OF SIGNAL OUTPUT COMING FROM THE CENTRAL CAP INSIDE THE PYRAMID?.THANK YOU.
I have a very good scope, but no pyramid (still working on it).  Maybe in a few days...  :)
