First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Drannom
This is my feeling to what happen in this thread
In the first page that was the real sincere Thomas, then his website was under attack, then he disapper 15 days ! , and when he reappear he was not the same, he has been replace by another paid conspiracy agent to fool us all,
or it may be from the beginning that he was not really him ?
anyway that is a good sing,  that is a probably a working device and we have not see it yet
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
fritz
Quote from: Pegasus on July 20, 2008, 07:21:14 AM
I belive is the same: Office@trawoeger.net  was the same email Thomas gived at the beginning,as I remember.
If you look into Austrian telephonebook - there is a transport company with
the name "traw?ger" - but the firstname is different - probably a close relative.
Thomas?s company - at the beginning of this things - was to guide danger/oversize
transports.
So thats the HP of a brother, uncle, or who knows....
guruji
Pyraman did you manage to build this pyramid?You said that higher beings are in contact wih you.
So please can you ask them what one should do if we have become caught in this selfish game of this world lead by selfishness.
I think it's impossible to stop using cars these days.
If we're going to get punished cause of these selfish people of this world; it's not fair for us selfless ones who trying hard to find alternative energy.
Can there be more help to us?
Thanks
Drannom
oye oye
there was a magnet in this pyramid !
look that link and be surprise
http://www.zpenergy.com/modules.php?name=News&file=article&sid=2381
It seems that a quite simple set-up of a home-made capacitor and two home-made coils, stimulated by a magnet, positioned at the geometric center of a metallic pyramid will produce appreciable amounts of current, enough to run a small fan.
QuoteIt sounds like to me by just reading your post, that the device is basically a form of homopolar generator, using the earth's magnetic field on the outside of the pyramid. The magnet seems to concentrate the flux and cause a power to be induced in the copper? He did mention that the dc is a pure dc, just like a homopolar generator would produce.
at rexresearch.com i saw the same description with a magnet in the pyramid
so from the beginning of this topic there was no magnet at all, how can it be possible ?
Quotefrom Stefan Hartmann's OverUnity forum:
was there a magnet or not ?
the real Thomas was using a magnet in his pyramid ? ahhhhhh ok
nitinnun
forgive me if this post sounds harsh. but this needs emphasis.
the magnetic field in thomas trawogers "cluster-mid", was so screwed up, that he needed the magnetic current from that magnetic, just to charge up his capacitor!
in my pyramid, the peak is copper, and the base is aluminum.
the peak is strongly positive, and the base is strongly negative.
my pyramids magnetic current, ONLY flows from the peak, through the middle, to the base.
in one united direction.
my peak-antenna collects this nice unified magnetic current, and sends it to the positive half of the capacitor.
(the counter-clockwise coil on my peak-antenna, converts the clockwise spinning positive charge, into counter-clockwise spinning hot electricity. which could be used to power a CPU fan)
my base antenna, collects this nice unified magnetic current, and sends it to the negative half of the capacitor.
MY pyramid, should not need a magnet to work.
because my pyramids magnetic current, is all flowing into the capacitor.
------steel frame:
his entire pyramid frame was steel.
which is good at storing negative charge, and poor at storing positive charge.
his peak and base were both negative steel, and they were not sepperated electrically in the middle.
thomas trawoger was also using the entire pyramid frame, to store the negative magnetic energy.
------copper loop:
the copper loop in the middle, acted as the copper peak.
it was badly shaped for its job.
it needed to be shaped like a peak.
the copper loop was surrounded by the negative steel frame on all sides!
so the positive charge in the middle, wanted to flow to the steel pyramid, which was in all directions around it!
the magnetic current did not go from peak to base.
it went from middle, to 360 degree's all around it.
only the current of his magnet, was pushing magetism into his capacitor.
which is why the whole damned thing stopped working, when he took the magnet off.
------central capacitor/antenna's:
the "central capacitor" in the middle of the copper loop, WAS THE PEAK ANTENNA.
it was JUST an antenna. which collected positive charge.
and it only had one connection. which was too the positive half of the capacitor.
no matter how this PEAK ANTENNA was hooked up to the copper loop, the whole damned ANTENNA, was ONLY positively charged.
the negative half of the capacitor, was soldered to the steel pyramid frame. so the entire steel frame, was used at the base-antenna.
------counter-clockwise wire coil:
one of the wire coils attached to this peak-antenna, was spun counter-clockwise. so it was able to convert the positive energy, into hot electricity.
that thomas trawoger also had a clockwise spinning wire coil, makes me think that he ripped off his idea's from les browns pyramid, on youtube.
in the end, trawogers pyramid could generate voltage.
but his pyramids magnetic current was so incredibly screwed up, that he needed the current of that magnet, to charge up the capacitor.
most of you are attracted to the idea his pyramid ran a fan.
and that the ugly mess in the middle looked complex enough, to work.
not because thomas trawoger taught anybody anything.
