Magnetic force and distance
Started by Shinecat, January 20, 2006, 08:17:38 AM
Honk
It does not increase. You have read the table backwards.
Magnet Power equals Clean Power
ken_nyus
Ah, I get it now, 0 is the center point between the two magnets, and 0.625 is at the face of one of the magnets.
Thanks.
ruin41
Wow its good to see that there is information available these days ...there wasn't when i started on this stuff ... good to see the right questions being asked too.
If you want an easy way to figure out the "power" of a given magnet it is easy ... use your kitchen scales ...stick a magnet on them and push against it with another it reads pounds or kg ... simple enough to understand and accurate magnet strength comparison.
If you have the wall mounted plastic scales like i do then you can put a magnet in the bowl and test the pull power as well from underneath.
Craigy
It is good to use the magnet sales calculator  http://www.arnoldmagnetics.com/mtc/calc_gauss_cyl.htm
when using a cheap Hall based Gauss meter, The a1301 or a1302 will normally saturate at more than a 1000 gauss, so if move to a point say half an inch away from the magnet under test we can calculate its surface flux value. The formula used on that page is this, Below that i have transposed so that you can work out your surface flux by taking a reading on your cheap gauss meter some distance away from the surface.
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
Honk
