THE WAY OF THE CRYSTAL
Started by FreeEnergy, March 08, 2009, 04:20:00 AM
pese
All this cant work to extract some free energy from univers (or radiostations).
As child (60 years ago) i learned from my father (radio-repair-mean) , So i
made experiences enought whole my life , because this was later my proffession...
YOU must not try !
The only way to absorb (robber) energy is, if you are placed directly
some meters (up to 100 / 200 Meters) in near from strong radiostation.
(longwave, Berlin) people in garden-areas. that was directöy under the Antennas have
done this to illuminate there gardens. 1930 . !!
I also have used (1950) this way (as child) to learn, I lived directly in near to MW station
(not more existing)  An i light on an flashlight lamp, i i come in near of the transmitter Antenna (50 Meters)
THIS ENERGY is NOT FREE .
All this that we sucking outside.
WE must POWER this into the Antenna
(I learned and tested this later if i was also constructig smal (later bigger)
transmitters. -Only for fun and learning-
Pese
HERE ANOTHER WAY  ???? :
energy
http://www.youtube.com/watch?v=nISNC8TUIUk&feature=related
http://www.youtube.com/watch?v=4BB9CbAj6y8&feature=channel
devrimogun
Quote from: Koen1 on March 09, 2009, 11:49:36 AM
Okay, this is actually kind of funny :)
Half of what the guy says is true, the other half is bull.
What he has there is a simple Germanium diode, probably
a verys sensitive low voltage one like the ones used in so-called "crystal radios".
As he describes, in his "crystal necklace" he basically has a circular antenna
connected to the diode, and the other end of the diode to a capacitor, and that
capacitor discharges over a tiny little coil.
This tiny coil, he claims in the video, puts out "the energy" and passes it
into the body of the person wearing the necklace. And this is supposed to heal?
Well, the very basice setup of an antenna, a tuning coil, a capacitor, and a sensitive
diode, is in fact the age-old schematic of a "crystal radio". (aka "foxhole radio")
This type of radio typically uses a very sensitive Germanium diode of the 1N34 or FO125
type, which is extremely sensitive and perfect for isolating or "detecting" radio waves
in the AM (&MW) bands.
A Crystal Radio needs no batteries, it operates on the energy contained in the
carrier wave of the radio signal.
Crystal radios have never been claimed to heal people at all.
It is possible that the maker of the video (and the builder of those necklaces)
has tuned the LC circuit, that is the capacitor and the coil, to a specific
frequency that stimulates "healing" according to the Rife radionics frequency
lists or something like that. The LC circuit can act like a self-oscillator,
depending on the value of the capacitor, the gauge and number of turns and
diameter of the coil, and the amount of charge fed into the coil.
So if that is the case, then he is simply using ambient "radio" (e/m) waves
to charge the capacitor via the diode, then the cap and coil go into
oscillation untill the energy feed becomes too low.
Anyway, YES you can use a similar circuit using germanium crystal diodes
to "capture" energy from the air and charge a capacitor, which can be used
as energy source for small devices or circuits.
The theory can all be found if you study Crystal Radios, but you don't really need to.
You can also try to replicate the "Tate Ambient Power Module";
this is a very simple circuit of 4 Germanium diodes and 4 capacitors,
which acts like a sort of "trap" for electromagnetic fluctuations, and turns any
detectable radio signals into charge on the caps, which can be used as DC
to power small devices.
In theory you could make an even simpler version with 2 diodes and 1 or 2 caps,
but that would not work as nicely... but it would work, just like the "necklace" circuit.
Here is a link to fairly extensive documentation on the Tate APM:
http://www.rexresearch.com/tate/tate.htm
Also, you can search YouTube for a video titled "energy from air", there's one
or two on there that show people's replications of such a TAPM circuit,
and how much volts they're getting from it.
So yeah you were way off in approaching that necklace fellow but in fact
the basic elements he uses to make a crappy little device can be used
in different circuits to actually collect energy from the environment.
Ok, in practise you will most of the time be picking up and rectifying
radio signals from various sources, but in theory you should also
be able to pick up "ground radio" (seismic e/m waves) with it.
Hope that helps? :)
Kind regards,
Koen
@Koen1
Beautifully explained. Tate device is one of the very few free energy devices
that actually work and can easily be replicated.
In the old mans setup would that heal? I am not sure.
It can supply extra energy in the LW/MW frequency to our energy bodies
(you may have heard about the aura, chakras, meridiens etc.)
But I am not sure if that would energise our bodies enough or in a proper way
to stay healthier or stronger. Here, what comes into the equation is the "belief"
If you can make a person believe that you healed them they will be healed
whatever the problem is. I am not going to get into any details here for that but it is so.
That might be the way the necklace effects its wearers or it really energizes the body somehow.
Piece,
Devrim
devrimogun
Quote from: TheNOP on March 09, 2009, 09:24:32 PM
depending of how much sterling silver is used in a necklace, it might not be such a big rip off as we might think.
Moreover, do not forget the crystals in the necklace. He is using beads of different crystals
on the upper part of the necklace.
Whats more is that, he is a VERY OLD MAN. Even if he were a crook (he is not)
he deserves some respect as the other things he said can not be said by an ordinary
person. In order for a person to be able to say those he must be highly intuitive.
In order to become intuitive one needs to deserve it with the level of consciousness.
Just show some respect and love to anybody you will always gain from that.
(I am telling this to everyone not one specific person)
Piece,
Devrim
Koen1
Quote from: pese on March 26, 2009, 06:31:36 AM
YOU must not try !
Yes, I know the anecdote, heard it from other sources too.
But then again, those people lived right under those big antennas,
and knew there was power being pumped into those antennas,
so I suppose they simply put 1 and 1 together to make 2,
and decided they could tap some of that power since those
allied radio stations seemed to have enough anyway and they
had too little themselves.
I am not entirely sure if that proves in any way that such diode
arrays cannot do the same with natural e/m waves, so I am
not convinced that it is impossible to get power from such an
array that is not transmitted to it by a manmade radio station,
like you seem to be saying.
QuoteI also have used (1950) this way (as child) to learn, I lived directly in near to MW station
Obviously not. There needs to be a source that produces electromagnetic waves or fluctuations.
But that source need not necessarily be man-made.
Could be "ground radio" as in seismically produced e/m waves.
Could be the "static interference" that is produced by lightning.
QuoteAll this that we sucking outside.
So basically you were experimenting with what... crystal radios first,
then tried some wireless power transmission experiments just like
those "new" wireless charger tests they have recently been doing
to develop phone and laptop battery chargers that are cordless?
Or was you focus more on collecting energy from the environment,
from radio noise and carrier waves?
QuotePese
energy
Can you perhaps give a transcript of the text in English?
I would like to know what they're talking about but unfortunately
can't understand a word of what is said.
Kind regards,
Koen
triffid
