Leedskalnin
Started by Big, January 24, 2006, 01:40:12 AM
0 Members and 82 Guests are viewing this topic.
quarktoo
Quote from: ramset on December 14, 2010, 04:20:18 PM
Well I just spent the last 10 minutes listening to William,
A wonderful man!
Grumpy I said you might call
He loves to talk,but has not gone public ,thinks he has a company ready to step up.
Spoke a lot about low mass electrons,said he's having chemical problems?
And the only coils he had working in any way were very .fragile
If I remember more I'll post it.
Chet
PS
Grumpy,I think You said your first name once at another Forum
That's the name (first name only) that I said may be calling.
He's a really cool guy
PPS
I told him we were just a few friends that were very impressed with his patent (fascinated actually)
and we were trying to understand it .
He will probably require an NDA ,but the jist of it is on these pages as
The buzz has said
Because I read the info that buzz gave (2links)before I called ,a lot of it clicked
I also ask if there were any "elements" involved(as in the Hubbard)
He said no!
That's when he went into the low mass semi conductor deal.
I read through the patent a year or two ago and yep, you just reminded me about that low mass comment. I have no clue what that would be but here is my guess.
That would not explain the free energy so maybe it means that the field is accelerated, electrons are fractured and resulting in mass to atomic energy conversion. After collision, mass is reduced as energy is converted. Not all particles have the same mass/energy level to begin with.
What if the inner and outer coils pump each other faster and faster. That could account for the fragility of the coils since the insulation would break down pretty fast. Higher voltage = higher electron velocity.
I don't have clue about the low mass semi conductor. I live about 15 minutes away from the guy and thought about looking him up but never have.
ramset
quarktoo
Call him sometime ,He's a good man.
Chet
Thanks Grandma
giantkiller
quarktoo
Quote from: giantkiller on December 14, 2010, 11:42:56 PM
www.planetary-engineering.com
You should team up with Gravity Block. If you look for patterns in anything, you will find them because everything in the universe is connected. Problem is, the pattern only tells the story you assign to it and the pattern may have no meaning at all or a completely different meaning.
The Movie A Beautiful Mind is about such a person working on a code project. The obsession of looking for the pattern blocks out everything going on all around you.
I will try and put an experiment together regarding Ed's motor that will have a classically trained academic scratching their head for eternity if they use classic EM as an attempt to explain it. To understand ED's motor, you would have to undo some of the mistakes Einstein made when he screwed up Dirac and Maxwell's work - just to name a few.
A particle is made of two waves. One is anchored in a light speed faster and the other anchored in a light speed slower. There is a reason we can only account for 4% of the light in the universe. The other 96% is not in this frame of time.
Maybe when Ed made his motor, he was just killing some time?
ramset
Sir ,
The Marinov motor and Eds motor
can you explain some more?
seems as if your words below speak the absolute truth
quarktoo
quote:
I try and put an experiment together regarding Ed's motor that will have a classically trained academic scratching their head for eternity if they use classic EM as an attempt to explain it. To understand ED's motor, you would have to undo some of the mistakes Einstein made when he screwed up Dirac and Maxwell's work - just to name a few.
Chet
Thanks Grandma
