Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
MasterPlaster
Didn't Meyer say that in his VIC circuit at resonance the pulses are doubled?
Please some one point me to that note.
This is all I have found by myself but I think it is something significant:
Memo WFC 426:
...outputting Voltage-wave signal
(64a xxx 64n) being a pulse-frequency doubler due to Inductance Reactance (FL) of Inductor Coil .....
and
Inductance Reactance performs several functions simultaneously or to given stimuli: increases applied voltage amplitude (Vo - Vn), doubles input frequency....
Secruoser
What is the simplest setup I can make as an experiment?
h20power
Hi Again,
The easiest one to build is the 8xa circuit just be sure to add in the 60n variable resistors as shown in the patent.
As for the doubling of frequency that is due to the two charging chokes L1 & L2. L1 is a LC circuit and L2 is a LCR circuit. The wave form coming into the blocking diode from the secondary coil is an AC sin wave that is cut into a half wave by the blocking diode. Once the pulse terminates in L1 the magnetic field collapses inducing a charge on L2 which sends it's induced pulse AC sin wave to the secondary, acting as a resistor, to the blocking diode. The pulse is 180 degrees out of phase so it fills in the half wave coming from the first pulse of the secondary coil. When you look at it on a scope it looks like it double the frequency, but it is two separate charges you are seeing from L1 and L2.
Hope that helps,
h2opower
happyfunball
Do you have a working system powering an actual vehicle h20power?
h20power
Quote from: happyfunball on February 24, 2011, 05:06:32 AM
Do you have a working system powering an actual vehicle h2opower?
I wasn't going too, but since gas prices are suppose to be headed to around $150-$200 a barrel I think I should go ahead and convert me Scirocco & Jetta over to a water car now as I won't have Meyer other technologies up in time before the increase in fuel prices hit. I have to work on the circuit a bit to get it to work with the two cars, but I have other plans in the works for other types of vehicles coming in the future. These I will promote with my company as Meyer's technology is vast in giving things energy independence.
h2opower
