Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
guruji
Hi H20power where is the H11D1 setup found?
Thanks
illuminati
Hi all i like to add my bit on the vic.
Meyer did not make it easy to build the vic from the patents but had plenty in there to hang u in court. He talked of EBP this was the way he trapped electrons in the secondary coil, u should only have a small leakage current if the transformer is shorted and the full voltage should remain across the secondary, if it dosen`t do this then there is no current restriction or not enough.
He said the primary is bi-directional wrap...bi is 2, 2 directions and wrap means wrapped around the former. The bi-directional is one half of the transformer primary is wound in one direction and the other half is then wound in the opposite direction forming 2 coils of opposing magnetic fields, this is wound longitudal to the inductors and secondary.
To make it easy to test only the inhibitor choke needs to be wound, wind it bifilar on a tube and place in the center of a ferrite e-core and dont pick one to small, then wind the primary as described above from inside edge to the center of choke then reverse wire direction to other inside edge. Now wind the secondary over the top of primary in same direction as choke. i used thin wire for choke and secondary and bit thicker for primary.
Use a frequency generator and driver circuit to test, u will need to align the coils including the primary, just short the output and when u still get full voltage its working. If u use a scope i have had some odd effects, on x10 it attenuated the signal (volts adjusted on scope of course) and the ground might cause a problem. Measure voltage across secondary. I used a diode in the circuit with a low forward volt drop.
Now u have a current restricting transformer...happy days!   ;D
h2o this is the transformer i was on about.
guruji
Thanks iluminati for your info. Can you please post a diagram?
illuminati
My drawing is poor and tends to take me hours to produce substandard rubbish so i was really hopeing the text would do, what bit are u not clear on?
