Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Quote from: alan on May 06, 2022, 09:00:30 AM
Hi Edward,
people want to see bubbles before they consider donating.
I am sure that the tech works, both output coils counter each other by mutual inductance when current wants to go, while voltage is allowed by transformer action of the two output coils added upon the voltage of the copper secondary coil.
I'm not sure about that as I showed this video years ago and got zero support, but I did get a lot of people accusing me of cheating: [size=78%]https://www.youtube.com/watch?v=hW78gKn1ZZ0[/size] I showed this video as it was the first time I got the technology running correctly. It has taken me some time to get the needed machines to be able to make the transformers in such a way as they don't short out on me and right now I just need one more machine and I should be able to go into a limited production with this technology.
There are just a two of us working on this technology that have managed to get this type of gas production with this technology that I am aware of. Just like me he too got accused of cheating and eventually he ended up throwing in the towel due too all the negativity he got from the forums. These transformers are tough to make correctly and it gets old having them short out on you all the time, but for me it's just another thing I have to learn and overcome. It's tough to move to the next level as trying to get the voltage to go to infinity you will run into all sorts of problems as the components must be chosen to handle the voltage increases. I fried many blocking diodes before finding one that would withstand the voltage levels and not burn out on me. Then I had to figure out which coating on the wires worked best with high voltage, still a work in progress but I think I got it well enough to reach the next level now. Then the resin used to seal the air out and keep the wires from moving cost simply went through the roof. I managed to get my hands on some but at a really high cost and I didn't get all that much of it. Plus the resin has a shelf life in that you must use it within a certain time frame typically 12 months or the stuff goes bad. I think the next build should do the trick but only time will tell.
Shalom,
Edward Mitchell
CEO and Owner
True Green Solutions
https://www.gofundme.com/f/energy-independence-for-you-and-me
alan
Looks good, are those amps going into the cell or into the primary coil?
Do you have progress to show from a later moment?
If you can feed the gas into a generator and power  a device, while monitoring VIC (input)  and device (output) power, people will be convinced that your claims are true.
You've added more  info to your post   Show a unit in action to get more funding.
Can you confirm by now that LCL and molecular resonance is involved?
How would you go to infinite voltage? By frequency or by dielectric voltage build up on the wfc?
are magnetically coupled, not capacitively; and to increase output voltage pulses.
h20power
Quote from: alan on May 06, 2022, 10:44:45 AM
Thanks Alan,
No not at this time as I must build the new transformer before I can get back to seeing if I can improve upon those results. Meyer stated in several of his lecture videos that voltage can take off to infinity if the electrical components allow it too. As I kept testing things out figuring out what worked and what didn't I'd be able to increase the voltage going to the cell. But with each new build the cost kept increasing basically slowing me down quite a bit actually. The needed component to be able to handle these high voltage potentials have a lot higher cost to them. With a lot of trail and error testing I kept increasing the voltage being applied to the water fuel cell but I reached a sticking point and only now do I feel I have learned how to overcome this. I stopped sharing any of these new improvements once I noticed that each time I would share an increase in voltage being applied to the water fuel cell it was met with hostility from many of the forum members as these new voltage levels were so much higher than what they were achieving with their work. I think the last scope shot I shared was me getting the voltages up to 8.8kv of potential difference and the closest person I have seen to this was just at 1kv with a similar WFC size. My success generally made folks upset so I stopped sharing my results but as I stated I did reach a sticking point.
To increase the voltage going to the cell all one has to do is increase the voltage they are sending to the primary coil. But what I have stated in this thread is the truth on how this technology gets voltage to perform work. The problem I see in people is they never asked what work was voltage performing? The work voltage is performing is ionizing the atoms that make up the water molecules getting them to release their electrons. If you get the atoms to release their electrons then the water molecules they have moved to form simply fall apart.
What most don't know is each time I'd figure a way to increase the amount of voltage being applied to the cell I'd find myself needing to get a new differential probe as I would reach it's limit. I now have three differential probes due to this. These differential probes are costly but if I wanted to proceed I had no choice but to buy them. The differential probe I have now is capable of reading up to 15kv and for reasons unknown the company that sold these probes seems to have went out of business now. Meanwhile back on the forums people were still arguing if the needed to get a differential probe or not as they didn't understand why such an expensive probe had to be used for this technology.
This is all part of making use of the scientific method as it can be costly to keep moving forwards but it must be done or you are stuck. For me this meant a lot of down time as I had to stop and save what little monies I had to buy the things I needed for this technology so that I could move forwards. The other guy I mentioned told me that this technology was simply getting to expensive for him and that with all the constant hate he didn't see the point of moving on anymore with this technology as it just didn't seem to get the support of the people he thought it would do. I am starting to feel the same way as people in general just can't get pass the propaganda put out by those that sell energy telling everyone that this technology violates the laws of physics. The reason why their propaganda is so effective on people is they have little to no understanding of physics and those that do never learned how to think outside of the box when it comes to learning new things that are not taught in the books they read.
People get made at me for various reasons but mostly it's because they can't achieve the results I have been getting as that video may be old but only one other person has managed to match that gas output and in fact he even beat my gas output numbers as he had more cells than I did at the time. It makes you wonder though in why these people even bother to wake up in the morning if all they are going to do is running around hating on people doesn't it as can't they find better things to do with their time? I find now that the one thing that frightens them is me achieving success in being able to actually push this technology into the marketplace as that really seems to scare the crap out of them. It's as if they put all of their monies into fossil fuel stocks and thus have a vested interest in seeing that those working on this technology and having limited success stop what they are doing so they don't lose their shirts.
Shalom,
Edward Mitchell
CEO and Owner
Vortex 22
Hi
This is very promising technology!!!
Dear Sir,
Where can I find a detailed instructions on how to build a WFC? Stan Meyer water fuel cell capacitors
The 12 arrays of water capacitor?
Thank you
God Bless You
Merci
Vortex 22
We all know how to charge a water capacitor to it's voltage dielectric breakdown ! ! ! There is no magic about that
We can do that using only  milli amps.
But it's possible to do that using only voltage and zero amps. I have done that many times with the mains ( 220 v ac / 50 hz)
So it makes sense to try it using high voltage and high frequency
! 10 kV / 30 kHz !!!
But
Can we have the same results using only 220 v and 50 Hz ?
