Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
HiggsField
Quote from: Chase212327 on April 10, 2009, 10:36:01 PM
Moderator,
RE:  "You idiot."
Are personal attacks and name calling OK?
May be you should have done a least a little research first before responding! If there was a moderator then STIRLING would not be profiting from this fraud. It's time to close this thing down.... "the pot calling the kettle black"
joe_1001101
Quote from: HiggsField on April 10, 2009, 10:23:41 PM
@joe_1001101
This is a pointless post. Who cares how he did his initial fraud, the fact that MYLOW has started posting again as if nothing had happened previously is proof  that this is a fools errand.
@HiggsField,
I care for one:)  Why not know how it was executed (if it was a scam)?  What else is there at this point?  Just like Mike's fake Window Motor.  I'm pretty sure I know exactly how he made that run, only after duplicating almost the identical effect on video.
Thanks,
Joe
HiggsField
@joe_1001101
You're right, it is important to know how we were all fooled, at least those in this forum who chose to believe without clear evidence. There was a lot indicators that this was a fake. Mylow refused to post a video meeting the requirements of the group in the early posts. He disassembled his prototype and began rebuilding. Once the MIB appeared on the scene, most of use knew that this was lost cause. However, there are nearly a weeks worth of posts discussing the reality of the MIB + profitiring on the back of the initial videos. Sharlatans always pray on the weak of mind.
queue
oopppss.. meant to post in builder thread .. oh well .. leave it anyway..
Still have a few things i wanted to test before i give it up and rake the yard  .. but i came across this config today ..
So far none of the original Mylow array configs i have tested have worked for my mags or my rig.
Today i tried a rotor array that seemed to work out pretty well. On the disk in the vid there are 2 different test arrays
but check out the one with 16 mags in it..
Interesting .. it's swings ..
i plan to test a disk with this rotor config continued around 16.3 or maybe 16.4
If this thing does work it's probably different for each set of stator-rotor mags one might use.
You tube is here ..
http://www.youtube.com/watch?v=5jEpD9hoiRQ
Cheers
Queue
joe_1001101
Quote from: HiggsField on April 10, 2009, 11:02:05 PM
@joe_1001101
Feel bad for Mylow if in the .00000001% (I believe) chance that it was real, things happened the way they did.   That's just me.  But I am 99.9999999% sure that the motor did not run as shown.
[update:  110% chance the motor did not run as shown]
Sorry to John Bedini that I keep bringing the Mike Fake Window Motor up, but it bothers me that it is still on youtube  FOOLING people.   Is this how it will always be in the FE field?
http://www.youtube.com/watch?v=g9ARja0DiT0
Thanks,
Joe
