Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 78 Guests are viewing this topic.
mikestocks2006
Hi folks,
What do think of this test/analysis?
The Force - analysis of Mylow's Magnetic Motor
http://www.youtube.com/watch?v=ZVyyu0qctYU&feature=channel_page
Thanks
Mike
queue
Quote from: vonwolf on May 15, 2009, 10:59:44 AM
  No, look at the vid., he shows the 2 stator magnets on the wider flat side of the bar then he sets it on the narrow edge with the stator magnets no where to be found? He didn't splice anything he sets the stator magnets off to the side out of the frame on edge?
   Am I seeing this wrong? The magnets are off to the left of that little wall and the Bar is up on it edge. As far as money, hundred and thousands of dollars? Well I don't know his motivation and that's my point, LOOK AT ME.
i came here to build an easy mag motor .. lol .. i spent thousands is about right . .it's good  my wife doesn't read here .. she'd wack me up side the head . . mostly she knows that i like magnets and she probably wishes i played with her as much as i play with them. yeah i would say thats right.
The domain names in my footer and in my Youtube movies are my own personal.
They say a bit about me and why i am here.
If you noticed in the vid near the start - i first position the bar in the near middle across the disk.
Shortly after that i then slide the stator into it's correct rotor alignment position. If it doesn't seem correct to you it's just the view angle. i copied all mylows vids - i know exactly where the stator is supposed to be as per Mylow.
What you are seeing in my vid is what happened .. there is no hidden agenda slight of hand or trickery but you may believe whatever you wish.
i do this for fun .. it's my hobby.
Queue
RunningBare
So that's why she keeps pestering me for more...oh dernit it, did I say that out loud. ;)
Quote from: queue on May 15, 2009, 03:20:09 PM
Quote from: wattsup on May 15, 2009, 02:43:08 PM
@TK
If you are logging revolutions, how come it went from 151 down to 55 then back up to 85.
@all
Just found out the importance of the bearing for my Pizza Pan wheel. I play with this while I wait for my main Mylow wheel. Well the free turning was really bad, so I took apart the bearings seals and saw that there was some grease. I removed almost all the grease then cleaned it out with some dishwasher liquid (good degreaser), then I sprayed some nice silicone in there and bingo, my wheel now turns and turns. Shit, should have done this from day one. It is as if I have a whole new super wheel to work with so back to the drawing board.
The graph shows RPM, my testbed is motorized as you know; I restarted the motor briefly to give the rise you mention.  The motor is coupled with a one-way clutch bearing so when the motor is off there is very little or no drag from it.
Near the end I positioned some random magnets underneath the disk to make an improvised eddy current brake to slow and stop the disk before the YT ten minutes ran out. These are just features to see how well  LR's method  is tracking. They have no other significance.
About the bearings: told you so. long ago. But even better than wet lube is dry graphite applied to an absolutely clean and dry bearing. Any wet lube will pick up dirt more rapidly. Believe it or not, a major cause of wear and spoilage in open bearings subjected to magnetic fields, is tiny nickel-iron micrometeorites in the dust that rains on us from space. They get in there and grind up the balls and spall the races.
wattsup
@TK
Thanks for the graphite info. OK I see about the graph.
@queue
How many HS90 did you order. Just placed my order and they are now out of HS90 till end of June. My other mags won't be shipped before end of next week due to no stock of HS811N.
So my question is, would your wife slap you less if you sold some of your mags to me?
