Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
CLaNZeR
Quote from: zapnic on March 26, 2009, 05:50:58 AM
something else
http://www.youtube.com/watch?v=mh4hwtszU_s
Could this be  the "Law of Unwinding Torsion Fibers"
Remeber playing with Paperclips doing same sort of thing a while back now, heres old video link
http://www.overunity.org.uk/ClanzSadAct.wmv
Grimer
Quote from: slipstream on March 26, 2009, 05:31:08 AM
#5 Regardless if HJ suffered degaussing issues (I assume he did, it's plausible to explain why his device isn't widespread), Mylow has explicitly stated that his motor does suffer this issue with the stator magnet.  That being the case this device IS NOT over unity, NOR is it a perpetual motion machine. IT IS a permanent magnet motor (assuming it works) which is an accomplishment all on its own.
The degaussing issue may or may not be resolved, but currently in my view the machine has turned stored magnetic energy into kinetic force, this does not violate the generally accepted laws of thermodynamics. Perhaps the magnetic energy is transferred to the rotor magnets (as has been suggested) even at 100% transfer the device is still not over unity. Maybe it dumps the energy in the black abyss or maybe it simply is so weak that the repeated exposure to the rotor magnets erodes the magnetic integrity of the stator, it really doesn't matter. It suggests that perhaps stored magnetic energy may be a viable energy storage medium or at the least that some work can be done via magnetic force until that force depletes/erodes/transfers etc.
It is not my intent to say it isn't authentic or that it is, only to share my two cents, whatever value you may find in them. To me Mylow seems genuine and unlikely to be a scammer or hoax. There are forces at work which he openly admits to not understanding (nor do any of us with absolute certainty) why it works (again assuming it does). It may work, it may not.
I can't agree with your point number five. The use of capital letters suggests you are rather uptight about the suggestion that the Mylow Magnetic Motor could be overunity. I believe it probably is - and is also an apparent PMM in the sense of having access to resupply from an inexhaustible source of energy, the ambient magnetic potential, a false datum just as the ambient air temperature is a false datum.
The slow degaussing of the stator could simply be the result of cycling, the net energy input to the stator in one half of the cycle being slightly less than the net energy output in the other. Also, though we know the strength of the stator magnet has decreased the strength of the rotor magnets may have increased. Steorn reported increase in magnet strength.
Omnibus doesn't consider degaussing a problem and I agree with him on that one, though not on his view that energy is being created ex nihilo.
Providing one accepts the existence of an ambient magnetic pressure in the same way as one accepts the existence of an ambient air pressure then I do not think the laws of dynamics, or thermodynamics, are violated. They are merely extended to areas previously undiscovered.
I do agree with you that Mylow is very genuine and if it's all an elaborate hoax then I'm a banana.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
k4zep
Hi All,
Mylow demonstrated a "gate" which is the kernal of the motor operation with FLAT magnets in a monopole orientation or he assumed they were in a
monopole orientation.  I watched a very early video of his on YouTube of this demonstration.  At this stage of his experimentation, I don't think he was using a simple
compass to determine the fields in magnets and I suspect the common Radio Shack magnet was  magnetized through the flat magnet and they were actually N/S top to bottom or
the opposite, but just a guess.
The difference between Mylow's and every other rotary motor attempt is that for some reason with his re-magnetized  "U" stator, the stator/rotor in a linear configuration (same gap between all rotor and stator magnets) Accelerates and does NOT pull back on the rotor magnets as they exit its influence in the direction of rotation, demonstrating an angular component or one directional field of integrated thrust in this configuration.......WHY?
Secondarily, the energy inputed to the wheel from a 3 or 4 string rotor set is enough to push the next string into the sphere of influence of the "U" magnet and so it continues.....If the stator was just a lump of ferrous material, the energy put into the wheel as it enters the group of rotor magnets would be almost identical to the exit forces subtracted from the wheel less induced hysteresis,bearing and frictional losses of all kinds and this makes sense.  IF all fields cancel out statically magnetically then the only losses would be hysteresis within the materials on the field as it moves plus those mentioned above and we would have a very small net loss....IF the actual drive is a real, active  spinning  field and the angular construction of the U magnet is producing this effect against the rotor magnets, then it is highly possible that the energy required to maintain this field in the working environment is coming from the residual energy in the U magnet and that is why it "runs down".
Assuming (hate that word) that Mr. Johnsons theory of spin in a magnetic field is correct, and these two interacting spins push the magnets forward,  I do not yet see the connection between the U stator and the Rotor magnets in this motor as the U fields NORMAL magnetic fields are so weak and the Rotor magnets are so strong that they simply should override the miniscule fields in the Stator and at any given point be attracted by the sum of their fields and the resultant attraction to the ferrous material in the stator  and the net results be zero......but visually, that is not the case! Is the  SPIN effect that strong as to override the normal fields and or does the kernel of how  this motor works reside in the fact that all normal magnetic fields are canceled and only the Spin fields remain???   Everything about this motor in conventional EXCEPT the "U" magnet.....that is where the questions must be and the answers must be found.  Please pardon the questions that I am asking myself as understanding is what I seek to this strange machine.  Is there a place with this motor when if the distance between the rotor and the stator were too close the motor would not run, that is normal fields would override the "spin" fields???
A QUESTION FOR MYLOW or maybe I have missed it and the answer should contain a clue as to its operation.
1.  WHAT DOES MYLOW DO TO REVERSE THE DIRECTION OF THE MOTOR??????
Anyway, drinking coffee, wakeing up, and thinking.  The rest of the day is all down hill.
Ben
oscar
Quote from: k4zep on March 26, 2009, 08:32:34 AM
He mounts the stator U-shaped magnet upside down.
He explained that in the interview
http://pesn.com/Radio/Free_Energy_Now/recordings/2009/090323_Mylow_MagnetMotor.mp3
The transmission was a '53 (Johnny Cash)
k4zep
