Dissociation of the Water Molecule
Started by Farrah Day, March 17, 2009, 10:22:06 AM
wojwrobel
hello
after studying for few months i think this is what will make as all happy
here are Meyer, Eccles and Tay-Hee Han mixed all together to make water decomposition most efficient
remember what Meyer said in hes video in Switzerland
http://video.google.pl/videoplay?docid=-2810004729743692578&ei=76Z2S7r5B4Ss2ALh4LnUBw&q=stanley+meyer+switzerland&hl=pl&view=3#
9:30-13:00
he energize water , water takes charge , then he elongate the molecules and they split
and that what i think it suppose to do
both pair of electrodes 1 2 and 3 4 are OUTSIDE the CELL wich is made out of plexi glass which has high dielectric strenght 30kv/mm so it sould be at least 2mm thick and spaced apart 2 mm
1 -60kv
2 +60kv
3 and 4 are 40kv ac 5khz to 50khz but 4 is 180 degrease out off phase
cheers from poland
wojsciech
WilbyInebriated
Quote from: Farrah Day on March 18, 2009, 09:08:53 AM
Incidentally for anyone that doesn't know - and I didn't - Stiffler was a forum moderator at one time. I found a Stiffler thread on this site of some 268 pages, over 2600 replies and which has been viewed over 140,000 times. However, it seems he was plagued by idiots and low-lives from start to finish, and I guess he eventually decided it wasn't worth the hassle to continue posting here - frankly it's not hard to imagine how he felt!
and yet now it's you filling that same role over @ energeticforum.com... how long till he decides you aren't worth the hassle and stops posting there? oh wait... you already caused that to happen!! congrats! ::) it's funny reading your first post in this thread knowing that you had not and STILL have not built a working SEC yet seem to know all about them. and you accuse the good doc of assumption... ::) are you still having trouble with those 15 components?
once again while others are demonstrating, you are still talking...
sparks
  I think it is ingenious using electromagnetic wave energy to disassociate water.  The electric field necessary to perform the work arises from creating standing waves in the water.  The currents are then generated between nodes of the standing waves.  There are no electrodes to degrade or workforce needed to be overcome to liberate free electrons that travel through a loop circuit.   I worked with electrocoagulation units that would use sacraficial anodes which would quickly form insulating layers of oxides.  The current then flowing from less and less surface area until the total active plate area diminished to a tiny fraction of the original reactive surface.   Increasing voltage would only increase the current in this tiny area with no gain in ions supplied to the solution just heating of the bulk severe pitting of the electrodes and deposition of oxides on the electrodes that were impossible to remove economically.  Even went to the effort of building a cell that operated using ultrasonic stimulation of the electrode.   The final design incorporated  a high velocity supply of the fluid to be coagulated that would scour the sacraficial anode of the oxides as they formed.  An indexing electrode would drill it's way through the sacraficial anode rod while the solution to be coagulated was forced at high pressure out of the end of the indexing electrode.  The fluid then traveling between the boring electrode and the sacraficial rod. It got the job done but was complex and suffered from intensive energy use to support the highpressures needed to provide suffiecient velocity in the gap between the boring head and the rod to scour the anode of the insulating oxides. All cells suffer from the loss of active surface area and cheap ones never had it to begin with.  Creating the currents right in the solution without use of electrodes is a pretty neat idea.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
CompuTutor
Quote from: Dave45 on September 13, 2009, 12:10:01 AM
solid water ice is the answer it doesnt change resonance or capacitance
Redacted, answer was to obvoius ...
Hope
Also coiling a few loops of copper wire and align the mag harmonics would not hurt any project.   Seems this tunes the specific surfaces to have harmonics that would be sync'd.
