The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
forest
Electricity in wire are many such electrons waves producing interference pattern. When all those waves propagate along wire we see difference of electric potential between points, named voltage.
At the very quick moment of connecting wire to source of electrons they meet each other and their own inward and outward waves and create complex interference stuck in allowed energetic levels between crystal structure of wire. However on wire surface they are not  much restricted...
Here we are electrons, as we call them now , particles stuck in allowed energetic quantum levels.
Now we need detailed theory about what is next when positive terminal is connected to circuit and circuit is closed... It's still unclear for me, but it seems that this may be related to changing phases of original electron waves... That would explain slow propagation of interference patterns ("electron particles") inside wire.
ramset
Gentlemen
Thank you for the privilege!!
Chet
Thanks Grandma
giantkiller
wattsup
I'll see the last Ditto and up it one. lol
EMdevices
Vital Clues from SM:
The inrush of current through the filament interacts with the
earth's magnetic field to produce a small kick.
SMALL KICK.
Those words mean a great deal.
It PROVES that there is an interaction between the magnetic field of the
earth and simple electrons running through wires.
It may be a small influence but it is actual OVER UNITY.
I have spent several years of my life thinking about that.
Scientists tell us that over unity is impossible.
They say that you cannot get more out of something then you put into it.
Then I think about that wire with the small kick when first turned on. . .
There in lies the secret my friend.
Current in a wire + external magnetic field =  "kick"  or physical movement or vibration of the wire !!
Don't let anybody else tell you that a "kick" is some inductive kick back voltage, it will lead you astray.
Another clue from SM:
Yes there is a genuine gyroscopic effect when the units are on.
Everybody has noticed that when held and in operation, the units have a
definite vibration and have a gyroscopic effect.
They seam to resist being moved through the air.
When placed on a smooth surface it is very pronounced.
Some of you should think about that.
and another one:
In regard to your query about the pulse DC conversion and the potential
use of the coil to provide motive force:
You could describe the useable current output of my coil as DC but
with some hash in it.
It really doesn't have any convertible AC component which could provide a
mechanical motive force as you suggested.
The multiple frequencies traveling around the coils are of too high
a frequency to provide for any motive effort.
They are only a means to achieve an end.
The multiple frequencies begin to feed themselves and the
multiple kicks become a combined big kick.
I call it resonating.
That is why if you notice in the video tapes that it takes just a few
seconds for the coil to begin to function at maximum effort.
You see, one little kick amounts to nothing.
However imagine if you had hundreds of thousands of little kicks
combining into one big current kick . . .
I originally got the idea from electron circuits which use vacuum
rectifiers like the 5U4 GB or 5AR4 etc.
The plate has a high voltage potential with lots of useable power available.
You cant get to it or use it for anything without applying a heating voltage
to the cathode or what is the cathode potential of the tube.
So, you put in a small voltage of 5 volts AC 60 Hz which heats up the
cathode and welcomes the electron stream from the plate.
Or actually the other way around, but not important for this example of
my thoughts.
Now the high voltage power goes through the cathode and travels through
the coils of the 5 volt transformer along with the 5 volt AC.
if the plate voltage is not rectified then it is AC with a potential 60 Hz
frequency.
That combines with the 5 volt 60 Hz in the coil of the htr transformer and
generally amounts to nothing.
In fact the power of the 5 volt transformer amounts to nothing.
It is an insignificant power supply,
except when the two transformers get slightly out of phase with
each other, or when they are connected in reverse of one another.
Then you can measure all kinds of things going on.
You can generate all kinds of hash and multiple frequencies, and I do
mean all kinds.
What I measured during this process was very interesting.
All these frequencies occasionally met at the same time with a
much larger kick at the output.
I was working at a laboratory at the time with much more sophisticated
equipment then is available to even most manufacturing companies.
I was able to analyses everything coming out of this simple two
transformer AC high voltage circuit.
In most power supplies there is lots of hash coming out and designers use
a .05 or so to short out as much as possible before it gets to the
smoothing capacitors.
This hash comes from the mains supply and especially from the
transformers themselves.
Notice this hash comes from the power grid ( or mains supply). It is the transformers nonlinear hysterisis that creates the power line harmonics (PLH)  that resonate on the power grid.
and more:
My units behave as though they are variable tuning devices, and
we are tuning them to a frequency just like a radio.
The closer you get to the center frequency the more power you
permit the collector to dissipate into a load.
SM is describing lot's of different angles of his technology,  it is a RADIO, it is a vibrational transformer, it is "kicks" , it is hash, etc...
Like I said before,  this is a high Q receiver, based on mechanical vibration (which has the highest Q).  I can't find the quote right now, but he mentions that after disconecting his TPU from the power supply, the voltage peaks up for about 5 seconds, and then decays back down to it's normal.  That 5 second is quite a key.  I'm sure most of you have pulses an LC circuit and noticed the decaying oscilltions, which last   micro-secons,  now try tapping a glass jar or steel bar, and you will hear the ringing for seconds !!,  That's the difference,  mechanical vibrations are less damped then electrical, so magnetostriction is the bridging mechanism between the two worlds,  electromagnetic and acoustic.
Along with this, and due to the circular nature of the TPUs,  rotational vibrations set in, which SM did not fully understand as he says so himself, hence the gyroscopic nature of the devices.
Anyway, chew on that   :)
EM
