The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
MACEDONIA CD
I GIVE SIMPLE  ONE FORMULA
  FOR WHAT IS MEAN IN TRUE  WHAT IS ENRGY  OF LEKTRYCYTY
<<IF YOU WHANT SOME ENRGY FROM ELKTRYCYTY  IS NEDD THIS  AND ALLWAYS YOU NEED  TWO INPUT ENRGY ALLWAYS  TWO INPUT
THAT TWO INPUT ENRGY  IS <<ELKTROMAGNET FILD OR MAGNET FILD
                                              << AND SPEED  OF THAT ELKTROMAGNET OR MAGNET FILD
AND FINALY  IF YOU ARE INCREASING ENY KIND OF THIS TWO INPUT SOURCE ENRGY   YOU WHILL HAVE ALL WAY MORE OUT ENERGY THAT IS  MATHERE  ANSFER OF THATA
I ASK YOU WHAT YOU NEED  FOR GET MORE  OUT ENERGY
TO INCREASING THE FILD   ,,,OR  SPEDD  WHAT IS EASY FOR YOU
Magnon
Quote from: AhuraMazda on March 21, 2009, 07:58:44 PM
@Magnon,
I hope you read my earlier post:
http://www.overunity.com/index.php?topic=7046.msg164954#msg164954
There are big implications in the documents I mentioned only I am looking for confirmations from
other people.
@macadena, I am glad you got your keyboard fixed!
Thank you for the link, i found it is very very interesting. :)
Especially Lakhovsky transformer, i did not know about that before. See image No 36, this is just what i have been trying to tell about.
Have you used / tested the TPU Excel calculator, that is available in Acoustomagnetic TPU / SEG calculation model thread in this forum? The idea is to use prime numbers of wavelenghts around the core, this way we can create a stable nested EM pattern around the TPU, because there are not subharmonics frequensies at all that can form EM fields in a wrong places between nested EM fields.
This same phenomena is measured by Roschin & Godin in their SEG replication.
Now we have two different devices that uses this effect, and i am sure that TPU uses this phenomena also.
--Magnon
giantkiller
Quote from: AhuraMazda on March 21, 2009, 09:18:23 AM
Sadly my brain has over heated after I read this document:
http://www.scribd.com/doc/13491267/Some-Free-Energy-Devices-eBook
(EM you don't want to miss this)
In it, it said that Hendershot had said what gave him the idea was the "earth induction compass" as used by Lindenberg in his historical flight. As usual all these comments seem to be hear say.
My further reading led me to pattent USRE21156 by Henry D Oakley. I am trying to work out what was powering his device. Some of theses compasses were made for planes and used the flow of external air to power them.
Although this post about Hendershot generator, my focus is still the TPU.
I am not discounting anything and thank every one of you for all your comments and GKs assistants!
In his demonstrations, SM always commented on the diameter of his coils I used to think that is something odd to mention . Reading Some-Free-Energy-Devices-eBook I think there might be a connection.
@exxcomm0n, thanks for your input. Wellcome.
They match speaker diameters.
wattsup
Hmmmmmmm. Lots of good posts.
I have a question. I have been pulsing a lot of my devices but have not figured out something that is critical and hopefully someone can clarify this for me. It is an electronics question but instead of looking at the TPU from the power production to the output, I want to look at it from the output to the power production or work backwards.
OK, let's say I wanted to build a TPU that will produce 120 volts dc or ac at 1 amp, I don't really care.
For the output of the tpu to support that kind of output and let's say the output is buffered using an output capacitor that has a value, well I don't know, let's say 20uf 240 volts, what does the production side have to produce.
May be a stupid question but here is what I mean.
a) Can I produce 1 volt 1 amp at least 120 times per second so that each volt will accumulate or add to the other volts in the capacitor up to 120 volts.
b) If not, can I produce 120 volts at .01 amps at least 120 times per second so that the amperage can accumulate inside the capacitor and get 1 amp. (or 1.2 amps)
c) Or is it only possible that the production side has to produce the 120 volts at 1 amp continuous into the capacitor/buffer to have it available as output.
Now in the case of the FTPU it was producing 60 volts but we do not know the amperage and I think after all my tests with similar rings that I got up to 132 volts but not enough amps to even light a 5 volt bulb. I am wondering that the FTPU demo never showed a load because it could simply not handle a load. It could only accumulate voltage but HOW can this be done circuit wise. Can it be done with a and/or b and/or c.
I'm confused as hell and don't have enough circuit savvy to figure it out.
My basic testing set-up has always been the same. I use a very nice dc pulse generator, or I use my frequency generator with a mosfet and my dc power supply or a battery as my standard drive end. Then I have the tpu build and then I send the output of that into my huge 88uf 1200vdc capacitor that has one diode to hold the charge inside the cap. Then I have my voltage meter on the cap to read the voltage rise (or no rise - lol). This is my standard set-up and with this, I can see the differences between one TPU build and another. Don't get me wrong, I have learned a great deal with this set-up but I need to know if there is a way to accumulate
Maybe to say also, if the SM FTPU circuit had to be patented, why the hell would you even want to patent a circuit that is obviously so small. What is it in the circuit that would be so innovative, so new and especially to such a degree as to warrant a patent. Could it be because it can do either a or b as asked above.
otto
Hello all,
@AM
no photo but I can easily describe you my setup:
you would see a 6" TPU sitting inside a 15" TPU, made with 2 copper rings, thats all.
The 6" TPU is a regular toroidal transformer with an iron core. You can buy such transformers, even in my country. the voltages are: 230V/ 10V - 0, 18V - 0 - 18V, 20V - 0.
I have connected this transformer to my 15" TPU.
Im pulsing the 18V - 0 - 18V secondary with 500kHz or less or any frequency I want and on the 230V side I have a really big high voltage.
@All
No, no typo, five hundred kilohertz. NO SATURATION of the core. Now spit on my words if you can!!! Its an oridinary transformer!!!
As Im still waiting for my 5U4 Im playing around with high voltages because a TPU needs this HV.
Why the core doesnt saturate? Ha,ha. I know it but here are a lot of people much more educated then Im.
Almost forgot: nice clean signals without hash!!!! Like with tubes.
Otto
PS: I think we have a lot to learn.
