The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
ramset
GK
I don't know if you have ever had the urge to say something,but didn't know how to put it into words?
I'll just have to say
THANK YOU [from the kitchen]
Chet
Thanks Grandma
Thaelin
   I just have to pop in here for a minute or two. I have been on a quest to understand
resonance. I found a pdf on the sour effects of it. Very sobering indeed. This was the
effect of someone inadvertantly hitting the 7th harmonic on a power factor correction.
It resulted in over voltage "and" over current situations and the cap was the unlucky
recipient of it.
   SM definately stated that his fundamental was 35k. He stated his top freq was 245k.
So now all we need is the middle one, pick it 3 or 5. Choose how close you get to the
actual harmonic to get your Q factor and that is your gain. He did say it "inherently will
run with gain".
   On another note, it was stated in the pdf that diodes on the output of a transformer
was a major cause of the harmonic "kick back" seen. On a three phase diode set, it
will have six (6) per cycle.  I can upload that pdf if anyone wants it.
thaelin
Mannix
Thaelin,
It sounds of great value ..please let it be known
thanks
giantkiller
@T,
Plz do. I am in the spot now of placing diodes. The .7volts wall can cause problems with the initial shock. It's(.7v) there and I want to know the ramifications.
In other words, where do we want the rebound at or just let it fly off somewhere. The RE doesn't see the diode. But I have concerns about the topology as a whole.
Does this make sense and is it clear to what I am saying?
Keely all the way. The frequencies you mentioned are possibly the ones that match best in copper molecules. Now if we had his trexnonar wire the frequencies would obviously change. It looks to be a conductive wave guide. He heterodynes the nodes of the frequencies and uses the latency of each material to his benefit. Gold, Platinum, Silver. And from this he achieves what I would call hyper-resonance.
Quote1. An extreme degree of resonance.
I think solid state is too chattery for this degree of exactness in copper. In other words the frequencies of copper and silicon substrate are discordant at some parts of their note scales or chords.
The Rodin coil approaches this type of operation. The cadaceus type winding has hardwired nodes.
I also believe that the magamp in the SM17 effectively controls the 'Effective aperture'. Otto alluded to this. Widen the mouth of this beast too much in the correct beat freq and, to paraquote Sparks,
QuoteYou have a gravity sucking nulcear runaway'.
In the microwave oven circuit we have an oscillation to a MOT to a LCR tank and the magnetron. This is a dischord drive mechanism. The magetron diminishes over time. The dischords are a product of mismatched impedances for the level of control we are speaking about here. Good enuff to cook food but a self disintegrator none the less.
Thanks.
--giantkiller.
BEP
Some time ago, on this site, I posted info about the rather nasty but useful characteristics some silicon rectifiers have. This info was found as reference comments in a manual about avoiding the effects on the grid from current 'we' call Telluric.
The problem was incredibly fast, high current and short duration reverse 'on' time.
Don't have access to my home puters right now or I would put a snippet here
BTW: No point in going into detail but 245 for a max was probably a literal suggestion. At just over 249 things could get ugly - resonance wise
