The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
otto
Hello all,
it seems that nobody wants understand and accept my wrightings. This IS the reason why SM maybe said that he doesnt know how his TPU works. He didnt want to fight with people about this. Of course he knows exactly how the TPU works but the problem is that its a little bit hard to describe and its also not so easy to understand.
Since Im tha proud owner of a 5U4 tube I knew that something was wrong. Wrong because my feeling said me that such a big tube has another job in the TPU. And I was right.
More later.
@Bruce TPU,
I know that all. I have 3 triodes and a 5U4 rectifier tube and tuned collectors.....you name it.
@dankie
who said that Im not in the middle of a fantastic team??
One of the guys has a knowledghe about coils you can only dream about and the other is a top 10 physicist. They dont want to expose themselfs so I dont want to mention their names.
Otto
otto
Hello all,
is here a good guy to post my schematic because I cant?
Otto
wattsup
@otto
I read your writings and will soon use them in my next build but I don't have enough guts to play with the tubes, not just yet anyways. I have an idea to use a tube in a loop that runs just by hitting it with one 12vdc spark, but I am too chicken to try it yet. lol
But something that may be of interest.
On @EM's thread about the HV lines, someone put up a circuit to draw ambient energy. I made one of the circuits and ran a wire out of my office and half way around my home. On that single input wire I got about 1.5 volts so nothing to jump about. But the circuit is using 4 diodes, four caps and the output is two wires, positive and negative DC. One wire in, two wires out. So I said to myself what better way to draw power from a closed loop by having only one input wire. I restarted my FTPU build and connected this to the collector loop and pulsed the outer four coils (2 x two levels) that were connected in series - half up to half down to half up to half down. This is now giving me the best results and if I now use @otto suggestions for materials and add the center toroid, I am sure it will be even better with much faster voltage rise times.
About the 3 frequencies, lets convene that it is possible for the MTPU/LTPU but I doubt is was also used in the smaller units. Example, the FTPU resonance between the outer coil and rings is in the 2.5mhz range according to my tests. Nothing in the 250khz or 35khz range. But again, if some basic configuration changes are made, this could also change. If 2,5mhz was the 7th harmonic, then what would be the first, third and fifth. Funny thing though, 5000 x 5000 = 2.5m
Grumpy
What happens when you pass one of those infamopus frequencies through this device? (See attached)
It becomes a train of pulses.  This device is shown in most of the TPU's, but I don't see anyone else using it.
Many of you apply all sorts of frequencies and many ways, but you are just guessing and hoping to get lucky.
        -Frank Edwards
AhuraMazda
@Grumpy,
It is interesting that you named your attachment "saturable inductors".
I must say for a long time I have suspected a TPU "connection" with magamps perhaps at the output stage.
The problem is I have not had much luck with my input stage!
It is not my style go around shouting Eurica unless I am sure what I am talking about so, this is just speculation.
P.S. Can anyone point me to where I may find S.M's demostration videos? I lost all mine when I had a computer crash.
For those who have working TPUs perhaps this is a trivial point,
from what I remember, SM always was careful to keep his TPU flat/horizontal. does this tell us anything?
