Thanks to ALL for your help!!
UPDATE: Testing the Perreault Valves
Started by Doctor Whodini, January 26, 2006, 12:34:35 PM
Dimasen
Stefan, Is the graphite rod diameter plays important role?
And, what gaz I must use in pipe?
hartiberlin
have not tested the dependance from rod diameter, but I guess the more graphite the better,
cause it will contain more radioactive isotopes, which radiate more when struck with a high voltage pulse.
Air as the gas is just fine, but a Russian researcher (Chernetsky )used H2 at
about 0.5 Tor pressure and got
5 x overunity results.
Have a look here:
http://www.nuenergy.org/alt/chernetsky.htm
Phil7218
Couldn't you also use a electrolyte instead of the gas? I think the key is to have many ions between two different kinds of metall or metall and graphite. It's the principle of many free enegy devices. H2 is maybe good as gas because it's very easy to ionize. But an electrolyte has a higher density of ions and you don't have to create them first with high voltage. Maybe you have to use a lower voltage to pulse such a electrolyt cell. And you have to find the right frequency to trigger it.
Doctor Whodini
I don't think a vacuum would work. So yes, a gas would be required.
Ros-Co.
Hi!
Unfortunately the first link is not work...   I would like some informations about the valves. I posted my first experiment with it to a Moray devices topic
Ros-Co.
