One magnet no bearing Bedini motor
Started by jonnydavro, March 28, 2009, 04:21:55 PM
gadgetmall
Quote from: xenomorphlabs on June 28, 2009, 02:10:00 PM
@Gadgetmall and Jesus:
Please forgive me to be so finical about it but i am still not sure about the cap polarity because of gadgetmall`s comment:
The original charge battery had its negative pole on the right and was connected to the positive of the source battery. Would it then not be logical to replace the battery with capacitors that have their pole orientation just like that battery?
Does that mean that you connected the diode that goes to the battery inbetween the 2 capacitors?
I have attached 4 variants that i actually see now.
Please Gadgetmall could you make a voltage measurement across your caps?
I am quite certain that the charging effect is mostly due to the pulsed DC component, because i have measured 0.6 Volts on my caps.
That is not enough to (hot)charge the battery with current, so it has to be something else.
Well the schematic i posted is correct and so is you number varant 1 .> i mus be going nuts because i thought the one jesus fixed did not have abattery on it ,now it does .
you are correct . i replaced the battery with the caps on the secondary , same polarity as the battery . anode positive and negitive connected directly to the positive on the run battery . Sheesss.. :) Still Ruunig but i adjusted it last night nad the volts are now showing 5.33 . I mess somthing up on the adjustment . Also not that the 10k pot is a CARBON audio pot on th eother side of the relay coil . thats all for now . i 'll try to get more time to study this running from ultra caps next week . i did try the 2.6 volts and got the same effect the volts went up  to 3.03 on that good battery .. On the diode i cannot replacate my replication with any other diode i have . sorry ..
Gadget
xenomorphlabs
@Gadgetmall: Thanks for taking the time to verify this.
Okay i have tried Variant 1 already and the source voltage dropped.
So it really must be a material attribute of the diode that makes your results possible.
Would be really interesting to give one to a lab to analyze it for something unusual hehe.
I can only find these diodes online in distributor-websites that seem to require you to be
an electronics dealer sending them target prices and requesting quotes or insane minimal ordering quantities or would not ship internationally to europe.
EDIT:
I just made a voltage measurement across the diode connecting to the battery and it reads 0.55 Volt.
So theoretically the diode would not be letting significant amounts of current through (<0.6 Volt).
How could i increase that voltage?
The the other hand i have tried it with germanium 1N60 diodes and it did also not work.
gadgetmall
Quote from: xenomorphlabs on June 28, 2009, 04:18:54 PM
EDIT:
So theoretically the diode would not be letting any current through (<0.6 Volt).
If i had a Spare i would let you get it . I come up with some rare stuff at that Milatary junk yard. I even got radioactive magnitite for the core material . theres like 10  55 gallon drums of the stuff . i got a little bucket full but have not tried to fill acore with it yet . scarry . I think the reason this one is doing this is MAINLY the Coil and the position of the trigger . Get them to run off 1 to 2 milliamps and then you wont have to generate much BEMF to power it or replenish it . I think . You asked me to check the volts across the caps . its0.98 and i am measuring the battery showing the results in the video . Fausto tried a different diode before he got some from me and was getting some feedback . you might ask him . He is great . He replicated My 48volt fan to the tee . Had it working great and bumped it and knocked it out of kilter .He proved i am am telling the truth and that all that matters . . I love my self runners . Its like an Alien Powersupply and once you get one running you will get Chills and a weird Feeling cause its cool and scarry  and then you realize that the government has this technology and we could have been powering for free all these years but the Oil biz would supposedly shatter the economy . BS .
Gadget .
brownsville
I tried to hook a power supply from an Epson printer to the output from the one magnet (5/8 neo inside aircore) and it worked for a while. It actually started generating dc power and I watched the voltage climb on the caps to just over 16 volts when I shorted it out. :-[ The wild thing is that in trying to do it again I took a reading from the input side and got a steady 123 vac coming from the coil while it was in resonance - I stopped the magnet from spinning and the coil started singing - I did a video of the process and show the voltage climbing until it gets to about 95 volts ac and then stop the magnet - in the vid you can hear the coil singing and the volts shoot right up to 123 volts and stays there. ???
http://www.youtube.com/watch?v=BfMqea8NC6U
After watching the vid I may be wrong in thinking that I had fried something, I am going to try it again to see if I just wasn't waiting long enough for the ac power to get up to the 123v to start charging the rest of the circuit.
The whole idea is probably stupid and if anyone knows this won't work I won't waste any more time on this...there are some really nice parts in this power supply that I can try in other adaptations. I was trying to get the dc and run it back to the source battery like Gadgetmall for a self runner and perhaps charger as well.
Brownsville
brownsville
Having trouble with the vid download and m youtube account....will post link as soon as it shows up.  >:(
