The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
dean_mcgowan
dean_mcgowan
If anyone can source the complete vid, i do remember he goes on to explain that this configuration also taps energy and seems to have the same effects as the SM device in terms of pertubations when moving it.
Mr_Video
here is a diagram & discription of the deyo coil that goes with the screen grabs I posted .
this does create a spinning magnetic field & has an air core .
www.americanantigravity.com/documents/Stan-Deyo-Antigravity-2005.pdf
mikestocks2006
Quote from: -[marco]- on October 05, 2006, 04:52:20 PM
so this means that we must transmit around the 7.8 Hz specially phased in order to recieve.
maybe thats why the voltage fluctates because its not steady but lightning in random order sometimes more sometimes less.
so the source isnt exactly "clean" also.
the only thing we then can do is send a signal out to see what it will give back.
@dave
dont you have some diagram of a transmitter in that range lying around?
greets marco
Hi folks, I?ve been reading this thread with great interest, and I have a basic question to ask,
marco, gnostik and many others have been mentioning a universal fundamental geofrequency of 7.4 to 7.8 Hz as the possible base driving excitation for the system.
The question is:
Shouldn?t the system be designed to resonate at that frequency?
I looked up some of the old dusty books for circuit frequencies,
f(Hz)=1/[2*pi*sqrt(LC)]
L in H
C in F
If it?s toroid shaped coil with no outside capacitor but suing the self capacitance equations for toroids
C= 0.29*L+0.41*R+1.94*sqrt[(R^3)/L]
C = self capacitance in picofarads
R = radius of coil in inches
L = length of coil in inches
Also more found here along with wire sizes aspect rations etc.
http://alumnos.elo.utfsm.cl/~bikers/TCC.html
shouldn?t the toroid be manufactured so it fundamentally resonates at 7.4 to 7.8 Hz
Also for the approx inductance for a toroid the plugins are here
Approximate Inductance of a Toroid
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indtor.html
Wouldn't solving the equations for materials, length, wire gage and toriod physical size a coiler should be able to get to the required frequency(s)?
I apologize in advance if this is way of base as I?m more into mechanics than electronics but I recall the scenarios in mechanical systems involving driver system and driven system frequencies fundamental/resonant and energy transfers along those lines for maximizing or minimizing energy transfer. From the driving system (in the case the earth field oscillator) to the driven system (this case an SM or any similar system)
Great thread both in cooperative and individual effort. Thanks
