The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
supersam
tao,
it appears to me both directions. what is wrong with that.  steven did say that current could flow both ways at once.  but it does look like a collision and or maybe some kicks are going to happen.  what do you think?  it looks like you would have something interesting happening with different frequencies, and different directions of magneticfields.  can't wait to see how you are going to tune these two frequencies to resonate.
lol
sam
c0mster
To All
I have put together a list of videos of my experiments tonight.  http://cmnet.ca/projects/roundcoil/index.html. Sorry they are individual movies I didn?t have the time to put it all together with a movie editor. If you watch the movies in order you can follow the tests. I think you will find the results interesting.
C0mster
exnihiloest
It is said : "The skeptics might say that the above-determined violations of the energy conservation are valid only locally for that small volume....
Therefore while gaining excess of energy in some places, we would loose the same amount at other places, and if the total energy balance were calculated for the whole space, then the law of energy preservation would remain valid. This explanation is however wrong and it can be disproved easily with careful and exact calculations even for practical cases, as Mr. Vajda has done it in his study."
How could it be disproved ? I didn't read any convincing argument. Any amateur radio operator knows that several EM sources create interferences in space. Waves add in some places and destroyed each other elsewhere, depending on the distances between the target and each source.
For example the waves from two equal synchronized sources add when the difference between the distances from the target to each source is a even number of half wave lengths, and substract when it is an odd number.
This principle is used by all directional antennas, even those with only one source connected to the transmitter such as Yagi antennas but where many reflecting or diffracting elements act as secondary sources. The result is that the radiated energy is concentrated in some places of space giving illusion of an energy gain when comparing to an isotropic source: in fact the radiated energy we can tap in whole space is the same.
Fran?ois
c0mster
Quote from: -[marco]- on October 06, 2006, 08:13:10 AM
Quote from: c0mster on October 06, 2006, 01:40:09 AM
To All
C0mster
hi cOmster  :)
nice videos  8)
Thanks Marco
Here again are the results across the 33ohm resistors: Input side .21V * .006 Amps = .00126 watts. Output side: .50v * .0149A = .00745 Watts. Pulse is 10 % on time 90% off at 3.57KHz. My next challenge is to develop a circuit to take the .00619 gain in wattage and replace it back into the driver. I should be able then to replace the driver battery with a capacitor, charge the cap, turn on the unit and have the cap never run down. Perhaps the kicks being referred to are the BEMF spikes produced in the driver coil.
To infinity and beyond.
C0mster
supersam
Quote from: Kosh on October 06, 2006, 05:51:33 AM
We should do the experiment SM suggested. A 5U4 rectifier with separated transformers and some phase control.
Now the high voltage power goes through the cathode and travels through the coils of the 5 volt transformer along with the 5 volt AC. If the plate voltage is not rectified then it is AC with a potential 60 Hz frequency. That combines with the 5 volt 60 Hz in the coil of the heater transformer and generally amounts to nothing. In fact the power of the 5 volt transformer amounts to nothing. It is an insignificant power supply except when the two transformers get slightly out of phase with each other, or when they are connected in reverse of one another.
Then you can measure all kinds of things going on. You can generate all kinds of hash and multiple frequencies, and I do mean all kinds. What I measured during this process was very interesting. All these frequencies occasionally met at the same time with a much larger kick at the output.
tao,
is this the tree you are barking up?  so what is wrong with having the magnetic fields going in different direction inside the colector coil?  it looks to me like your setup could do this with the right tuning.  or do think it is enough to have the fields just traveling around in different directions in the collector coil, slightly out of phase, to make the kicks?
lol
sam
