The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
supersam
guys,
what is a heater transformer?
lol
sam
ps: tao, shuttinup, shuttinup!  so no need to tell me.  lol
yea I know.
supersam
rich,
that seemed to be a great example of the classical understanding of waves as we were all taught.  do you remember the first time you were told that there was  a set of 'imaginary numbers"?
lol
sam
c0mster
Here is a excel graph representing correlations between volts driving the coil and measurements across the input and output resistor @ 33ohm
supersam
guy's
let's say, you have that same magnetic force, speeding along at the speed of light- the impedance of copper, how much power would you have? ALOT!!!
LOL
SAM
raburgeson
Notice in the picture of the large coil, wich way the wires are wrapped on the surface. Notice too were the outputs are located on the 6 inch coil. In an early post it was said power would be generated in perpendicular wires.
Why doesn't it work upside down. The magnetic componet of a potential is relitive of that potential. In other words a low voltage signal has a weak magnetic componet, a high voltage signal has a strong componet. The potential between your coil and ground is weak, the potential difference between your coil and the Ionosphere is great. On it's side it can still draw a great potential from beyound the horizon. The potential of the circuit is great considering the power of the Ionosphere. Pointed towards the ground there is not enough potential to cause a kick.
I've almost finished my new coil, I don't like to refer to any other circuit in discription. But what it looks like to me is we are trying to run a Tesla coil backwards. Instead of pulsing energy out we are trying to pulse energy in. I thought about wrapping one layer of perpendicular wire between my normal torroid wraps and continue these over the outer wraps. I've decided not to now though because air core mutual and self inductance is low Q, looking for the best possible inductance between coilsI need to keep the wraps as closely together as possible. If the outside perpendicular wraps don't act like a Tesla coil in reverse I can remove them.
Also I made a statement that was unfair earlier, Of course I know you can read. This subject is way hot, I figured  a grump would make site management realise even against policy This particular subject might need some language support. So of you guys are missing stuff, all of us need 100% on this.
