The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
mrd10
Hehehe  ok Dave,
Maybe, I still don't know, I'm like a big kid, i know.
Are you able to make that 555timer dc to dc converter, and play around with the two transformer you have, or build two or 3 of the 555 timer ccts and see what happens when you use em together?
I was even going to use a magnet and place it near by to see if this makes any difference.
Cheers,
Dom    :D
hartiberlin
Hi Dave,
did you try to put the 2 transformer input and/or outputs in series ?
Probably not yet , right ?
Graham Gunderson has seen some strange results,
when he pulsed or fed one transformer with two 180 degres out of phase
signals, so that they normally cancel each other out.
He also could produce a strange "ray" this way, which was
some kind of scalar "beam" or something simular,
which could knock off or influence things at a distance.
It must be still in my old
yahoogroups free-energy archive
or in the yahoogroups
ou-builders@yahoogroups.com
He wanted to offer kits of this design,
but then he went with MPI, where he now
has this new solid state magnet patent.
But I guess Steven Mark also meant, you must put
pulses into ONE transformer, to get kicks out,
and this is best, if you do it with a bifilar coil
or 2 x  180 out of phase input coils to see
some kicks at the normally canceled output secondary
coil.
Graham said, he had some strange signals at the secondary
this way, but when I remember correctly, he pulsed the the
input coils on the same transformer and
when hold into a direction of some metal image hanging at
his ceilling wall a few meters away, it shook and
his device produced some kind of scalar wave.
Later he tested over distances of at least 50 to 100 Meters
and it was like a light beam he said.
Unfortunately he never published his whole setup in detail.
But it had to do with canceling out currents in
2 primary coils in a transformer and then the
secondary output coil showed strange results and
the thing also vibrated in very peculiar ways.
Also you could feel this ray with your hands, so
it was influencing biological cells.
So Dave, please try it with one transformer and
use one, which has or instance 240 Volt to 2 x 12 Volts.
Then use the 2 secondary 12 Volts windings to put
your input singnals in there , so that they cancel each other out
and look at the other 240 Volts coil, what will come out of it.
Please also test this with your noise generator.
Many thanks.
Regards, Stefan.
hartiberlin
P.S. If you put 2 transformers input coils in series
and drive it with noise,
the input current might not draw additional current from
the battery, when the 2 output coils are also in series ?!
gn0stik
@Marco, can you film yourself turning that on please? ;)
@dave, all due respect, but isn't white noise too dirty to tell when two white noise signals are combining? There are all kinds of natural spikes in white noise.
Also, I thought you were well into operation when the spikes occured in your experiemnt, not when you just turned it on.
Regards,
Rich
gn0stik
Thanks man. Oh, and use your right hand to throw the switch keep your left behind your back... That thing sounds a bit scary.
@stefan, ok so the site is loading faster now that you have removed the banners, but now those automatic link things cause the site to throw a "site not found error" after it has already loaded, and it sends us to a dns error page, so that we have to refresh, what domain do those ads come from, so I can block them in my firewall?
