The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 717 Guests are viewing this topic.
2tiger
Hi all
It takes me nearly 5 weeks to read all the posts in this thread.
And for me it?s hard to believe what SM shows in his video. Nevertheless I?m still analysing this device and trying to understand it?s function.
If I would have the time to experiment, I?d try a few things. But I haven?t.
In the meantime I?d like to tell you the results of my analyses and all the questions I have about this device.
1. question for me is, what is this kick? Answer it?s a powerspike - however it has been produced!
2. If I find one of this kicks/powerspikes, how can I collect them to an usefull amount?
I read about that someone confirms that in presentation, the smaller unit drives a 100W bulb for several hours.
3. How can I collect such huge amount  of kicks in such a speed in this small device?
If this kick creates a powerspike of, let me assume, 1mW, the device have to collect 100.000 kicks every second the bulb is lightning!
If  Marco have find this kicks with the two toroids, one over an other, we can see and hear that the kicks comes very sporadic. So the conclusion of it, must be, that the device must be able to store this energy in any kind in order to release the power once there are 100.000 kicks collected. But remember this the amount of kicks for the first second.
The device have to act more like a battery than like a generator and be able to store ALL the energy for power the bulb for several hours.
4. Has anyone of you any idea how this can be made with only 1 toroid?
If the voltage of the smaller unit is 180 V and it powers a 100 W bulb (current 0,555 Amperes ) for let us assume for 3 hours then the device have to store energy of round about 300 Wh and the capacity must be 1,66 Ah /180V.
And this is the point where I would start with.
Because when I?m not able to store this amount of energy in this toroid, I don?t need to care about to find the kicks nor to store them.
Perhaps I?m wrong, but I don?t believe that this device creates 100 Ws "online" to power the bulb.
And this assuption is confirmed by SM himself , when he said that one kick is not much, but a lot of kicks can create a big kick (more power), so you have to collect them.
This are just my thoughts at the moment and I could be completly wrong. So feel free to kick them around.
It would be nice to hear /read any comment on this.
kr
2Tiger
dutchy1966
Quote from: ctglabs on October 12, 2006, 06:54:57 AM
Hi Dutchy,
I understand.  I was wondering the same thing.  Although people here don't believe what I have said about the sine waves in 100% adding when in parallel and 100% in phase, although I have tested this repeatedly now.  I do not claim there is excess energy here yet, only that the voltages do add, but only when the sine waves are in 100% phase and are of the same voltage.
So I have been wondering about what would happen if I used 3 or 4 or even 5 transformers to create 5 waves in perfect phase from one sine source and then add them in parallel and in phase in the mixing transformer again to add the signals.  The question at the moment I guess is will it work with more than two?  If it does work with more than two, then it will be the square of this, not the addition!  I know there is no such EM wave with a AC signal in a wire, not like a radio wave, it just appears so over time on the scope, but we must not forget that the actual energy (poytning flow) flows outside the wire and as such we may see a similar superposition of these energy fields.
I will be trying this with loop antennas soon!
Regards,
Dave.
Dave,
Could it alse be that the control coils (vertical and in sections) pick up this magnetic pulsetrain and that way indicates by the induced voltage how well the (magnetic) pulses are lined/added up. Then these coils can somehow monitor and adjust the pulsetrain?
Maybe you could test this theory?
Regards Dutchy
rensseak
Quote from: ctglabs on October 11, 2006, 06:24:15 PM
Quote from: -[marco]- on October 11, 2006, 01:49:50 PM
oh and dave  :) im from holland but i do have chips and beer  ;D
Hi Marco,
Perhaps one day we will build a working SM device, then we will meet and have steak, chips and beer!   ;D
Dave.
Would it possible to invite me also? I'm really surprised of the progress you did here all.
Your attempt with the three transformers reminded me of the HOPE generator.
Three is important. So why not two primary and one secondary coil on one an the same  transformer and than feed the primary coils with to different waves.   Two of this and the output coils connected in series or paralle (should be tested).
just my .02
regards
Norbert
gn0stik
I was wondering, Can you split it into four separate in phase signals to start, then feed those into two, then both of those into one?
It would probably lose phase along the way.
Just curious.
The best way to keep this going, is probably to split the out of t3 into the t1, and 2 of another setup then into a that setup's t3, see if you get a further gain.
supersam
dave,
first off let me say that your three transformer idea i think is pertinent!!!! i also think that marcos' two coils must also be pertinent.  there is probably some reason that steven has chosen to release a little more information at this time and drive an old point home as well.
i have been thinking about the pulsed dc thing and the similarities between your 3 transformer setup and the two capacitor light bulb and induction coil and how it can all be tied together with the toroidal coils.  you spent some time recently looking at longitudinal waves, which if i am reading right, steven is also talking about in the latest post.  also gravitomagnetics  which is still somewhat theoretical in it's usefulness.  i think we are going to have to find some way to tie it all together, but i also think for some reason that we have most of the parts.
lets just figure it all out and make on of these things.  have you tried pulsed dc through your three transformer setup? if marcos has two coils resonating with no aparent source of energy, where do you think it is coming from?  has anyone looked at the frequency of marcos' kicks? was there a frequency change, in your three transformer setup or just a doubleing of amplitude? with marcos' kick in the closup was shown several different spikes that  were of greater amplitude than the base wave.  as each spike of increased amplitude start to travel aroud the toroid, are they in fact creating several different frequencies that can resonate there own additional spikes?
just some thoughts.  i feel now you guys have answered some really important factors in the tpu, or steven would not posted and made so many other things to think about.
keep up the good work and let everyone know your thoughts on how all this might tie together.
lol
sam
