The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 25 Guests are viewing this topic.
hartiberlin
What is the simplest experiment to see this 'kick' on a scope, so one can measure it ?
DRAKE
HI All
        Iv been reading alot this seems to be making me think overtime.
Charged particles, like electrons and positive ions, cannot readily move across a magnetic field line. They can move fine along the field lines. In the cosmic arena, these charged particles will take the place of the compass needle in helping us visualize magnetic field lines. The point to remember here, for later discussion, is that a charged particle?s motion is constrained by a magnetic field, but a neutral particle?s (an atom or a molecule) is not.
Liberty
My take on the generator ring is:  The magnets on top are used to set up a magnetic field from a permanent magnet ring torid.  This field is close in strength to that of the earth, which is why the magnets are not directly attached to the ring, but are just close.  It provides a 'mask' or a beat frequency like an AM radio (but in this case a permanent magnetic field to beat with the earth's magnetic field).  The coil on the lower torid, is cut to a length that equals the beat frequency difference that is realized at the point of the coil on the lower torid. I speculate that the coil is not an open coil, but a closed coil to resonate near 5kz. (The frequency that is created by a repeating occurance of a cancelling of the magnetic field on the lower ring after the magnetic field of the top ring is beat together with the earth's magnetic field (which is delayed due to distance of travel time), the difference resulting in a harmonic (5kz) of the earth's magnetic field compared to the local permanent magnet field).
In short it creates a pulsing of a magnetic field on the lower torid which induces a voltage in the lower coil when 'tuned in' to the frequency of the beating together of these magnetic fields.
Am I getting close Mr. SM?
Liberty
Liberty
The kick implies to me that Mr. SM is introducing a frequency in the lower coil that invokes a pulse back of greater magnitude to start the system producing or oscillating.  Then the power is self sustaining?
Liberty
