The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
raburgeson
do you have taps on that monster coil to the collector cores so you can watch the phase relations between them?
gn0stik
Quote from: -[marco]- on October 13, 2006, 05:08:20 PM
Quote from: argona369 on October 13, 2006, 04:36:53 PM
Quote from: -[marco]- on October 13, 2006, 01:57:27 PM
Quote from: starcruiser on October 13, 2006, 01:38:04 PM
Quote from: -[marco]- on October 13, 2006, 01:03:20 PM
i have.
it looks like less with the wires looped.
it getting scary cause im measurin things that cant be.
Marco all 4 possibilities? with coils (top and bottom ones) both Clockwise, both counter clockwise (in relation to the center coils winding) as well as fliping the connections on the top and bottom so the top coils outside winding is connecting to the bottom coils inside and visa versa to see if the output varies substantially.
Carl
hi carl  :),
until now i measured 2 possibilaties.
the most outside wires and the wire from bottom 1 and top 3 coil.
in my next video you can see what happens when the output begins to feed the input.
marco.
Hi, amassing, truly amassing.
RE: part-3.wmv
Is this how its set up?
3 coils of iron wire (not parallel wound with copper)
All same direction wound. I.e. all clockwise (or counter-clockwise) looking downwards.
(a)Outside wire bottom to inside wire top.
(b)Inside wire bottom to outside wire top, 12 volt bulb in series in-between connection,
Or bulb connected between connections  a,b?
Middle coil fed ?juice? ac or dc? Voltage?
Mp3 players output center wire (hot) to finger. Sine wave? Frequency?
Other hand near coils pile
Cliff,
guys i said the bulb was for you to see how the coils react to my hand otherwise you would only hear the sound.
so the bulb is switched in with the juice wich is collector coil 2.
i did shortcut the outside two collectors cause then it reacted better.
in the beginning it reacted about ten centimeter now i got it to react as im standing a meter away from it.
its amazing and im still thinking about what sort of field it is.
as i grab the coils the frequency goes down but the output goes oup about 35 volt max.
then you can feel it resonating.
i did also quickly wrap a control coil around it as i put the jack on it then it goes to maximum output at once.the jack picks up the signal from the coil feeds it back into the transmitter and all starts over again.
marco.
This reminds me of the old days of antenna based TV reception, when you had to stand in certain places and move around the room to get the signal to come in right. This also happens with radio reception. The other day I went to the movies with a friend of mine and radio reception at his house was crappy, but when he started walking up to the car it started getting clearer.
So when you wrap the control wires around it @ 90 it pumps the reception up to full instantly. Interesting, do you still get any reaction with your hand/body moving closer or farther away? I would think not. So basically your body was the control. When it had no control, you held the input jack with your hand, and waved the other hand closer and farther away and that made the light go bright and dim. Now that you have a control around it. Do you hold one end of the control wire to produce the effect?
What will be interesting to see, is how the output raises with a proper control winding... ;)
starcruiser
Marco,
I was re-reading your posts and had a few questions,
what is the signal sources voltage?
Can you measure this?
You were using an MP3 player as the source correct? or was it something else?
So you have a 30 vdc source on the center coil and using another "music" source for the control signal correct?
I don't want to take you away from your coil winding but just want to help you document the existing parameters to help us all understand your experiement and help you, if we can, move forward.
I will be taking a trek tomorrow to the local hobby lobby to see if they have the steel wire and see what I can duplicate/do as well.
I'm in the states and still at work so not able to play along with you. I'm sure time differences won't help either.
Regards,
Carl
Regards,
Carl
gn0stik
Is it the hot side or the cold side that you can light the light with? TEM/LMD on steroids anyone?
sterlinga
Posted at http://peswiki.com/index.php/Directory:Steve_Marks_Toroid_Generator
Take it With a Grain of Salt
On Oct. 13, 2006, Mark Goldes, CEO of Magnetic Power, Inc, said:
QuoteI would take this with a very great grain of salt. Our team has looked carefully at this technology claim. We can't see anything in the videos that can't be faked (via batteries or wireless transmission of power). We also are privy to a person from Sweden who lost $80,000 to an individual (now deceased) in Perth, Australia, who said he had the authority to represent the technology. Furthermore, there has to be something seriously wrong if all these years later -- nearly a decade -- there still is nothing in the marketplace. There has not been any further news of prototyping and testing.
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
