The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
Jdo300
Quote from: tao on October 18, 2006, 06:29:13 AM
Quote from: -[marco]- on October 18, 2006, 05:42:41 AM
that joe thing is intresting.
there were some thing i did have a while but i didnt post them.
its about plasma stuff.
A short description of the particle orbits in a magnetic field, what a magnetised plasma is, and how electric fields give rise to collective drifts. This drift motion of the particle populations makes it possible to think of the plasma as a fluid
The orbits have a characteristic frequency, called the gyrofrequency.
small electric fields are always present even though on average the plasma is very close to neutral (note here that ``small'' can still mean 100s of volts per cm)
In the early phase magnetic reconnection is controlled by an ion kinetic effect, while an electron kinetic effect becomes dominant in the late phase.
so download the attached .txt file if you care to read all.
marco
Marco, I found this quote from your text file interesting...
"Lightning Strikes create powerful radio waves in the frequency range of 3 KHz (audio, VLF) through 10 MHz (shortwave radio). The VLF (3000 Hz to 30000 Hz) "lightning signatures" can travel around the world, allowing monitoring of world-wide lightning. The shortwave "lightning signatures can travel half-way around the Earth (the night-time side of the Earth). The best region to listen for distant shortwave lightning signatures is from 2 MHz through 7 MHz. After 3 AM local time you can listen to 3 MHz and hear the beautiful dispersion-ringing of the static as it bounces back-and-forth between the earth and ionosphere. It can at times sound like hundreds of tiny bells ringing at once!
UHF Television Signals easily reflect the electrical path ways that lightning creates! Tune your hand-held scanner (or TV) to the sound carrier frequency of a 200 to 300 mile distant UHF TV station in the range of CH 14 to CH 21 (you should NOT be able to receive the station at all under normal weather conditions!) When lightning flashes, sometimes you will hear about 1/4 second of the TV station's sound! We discovered this during an experiment by tuning a hand-held scanner to 475.750 MHz which is the sound carrier for UHF TV Channel 14 (normally "dead"here). We heard TV "sound blips" instead of the UHF lightning signatures we were looking for! Do not experiment when lightning is nearby!"
Hi Tao,
This information is amazing!!! In my transformer experiments. I always seem to hit the best resonant frequency from 1-3MHz!! I wonder if my circuit is tapping into the power from the lightning strikes?
@Tao & Tishatang,
Your ideas for the rotating magnetic field sound great! While reading through the posts on this, I was reminded of this old generator called the Gramme Generator. It uses a toroidal winding and two magnets along with two magnets outside of the toroid to produce power. There is this other toroidal motor which I can?t remember the name of but it uses a single toroidal winding to spin without alternating currents. Anywho, here is a link to some pictures of the gramme generator: http://www.uibk.ac.at/exphys/museum/en/details/mag/gramme.html
God Bless,
Jason O
Hello guys,
electricity =electronsgas and plasma also,unimportant the definition hot/cold ! !
About parametric generator:Prof. Ferdinand Cap.
Cap +C.F.von Weizsaecker(worked also with Bethe):
You will enter "Nuclear physics" and time-parallel "high-fidelity philosophy":
The "GOTT/GOD ???" Frage/question !!!
S
  dL
p.s.: I think that all this work is L.A.S.E.R./M.A.S.E.R./P.A.S.E.R. related.
mrd10
Hey Dave,
Good write up, I wish I knew as much as you did, I'm new to radiant energy and therefore what it consists of.
Did you read the thread and d/l the 4 videos that i think jason did, he was just pulsing a toroid transformer with one lead only, that is pos only, he hit a sweet spot of 9.2 volts in and was getting around 37 volts out i think, this was obtained at a certain frequency, i will see if i can findit and let you know, where it was, this i reckon confirms that we have something of radiant energy.
;D
Dom
