The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
JackFrost
@Mannix,
What are the patent numbers associated with Steven Mark's device?
Which UEC Corporation holds the rights? (UEC is an acronym)
It may be somewhere in the previous <500 pages, but I'll ask anyway, what makes Steve say that his device harnesses the earth's magnetic field?  Has he tried shielded it to verify this?
General comment:
Coil configuration is similar to a "scorch field" generator.  Would not be surprised if Steve tried one of those back in the 80's or early 90's - probably scared the hell out of him if he did...
JackFrost
Dual coil configuration consisting of a inner coil with an outer coil wrapped around it.  Like a typical toroid.
Apply 50vdc to inner coil and 25kvdc to outer coil.  Modulate (time varying) the field that is set up in the center of device.
This was the first mentioned I've ever heard of that had a coil arrangement like this.
Also resembles Bruce Depalma's model of the universe.  See Attached.
Also, if the coil stops working upside down, but NSEW direction has no effect, then it is not the earth's magnetic field, but gravitational field that is of consequence.
Puts the whole interia issue in a new perspective...
Undetectable waves,time-effect,...
keelynet:CSE-rays,Louis de Broglie and Grebennikov
Look for his,G., flying toy: platform weight versus force/velocity
S
  dL
gn0stik
Quote from: -[marco]- on October 19, 2006, 10:13:42 AM
Purple/blue colored spikes radiated in all directions along the axis of the power lines for just a moment.
i have seen this...
it was a wire on high voltage laying on the ground the whole wire was shining.
but as you grabd it then it was gone but you could not feel anything.
Maybe it's just me, but I don't think I'd grab a wire that was shining like that if I saw it.
Very interesting though.
