The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
giantkiller
@Tao,
Hi,
Did you ever post/attach the matlab file you talked about earlier?
That would be much appreciated...
-giantkiller
mikestocks2006
Quote from: ctglabs on October 20, 2006, 12:40:26 PM
Dear all,
Just a quick note.  I guess most of you already know about the wave/particle duality of the photon.  Different areas of science still call it a wave and others call it a particle.  The truth being its both and neither and changes depending on your relative view point.
One thing most people overlook is that the same interference tests have been done with electrons and other particles.  These tests have shown that all particles following this duality.  Electrons in an interference pattern can also appear like waves or particles depending on your view point.  The idea of them being small perfectly round balls is just a way of making it easy to visualise the atom, in reality its very different!  Hmm, the electron is a wave, not a particle, lol, does that throw a spanner in the works or what!
Dave.
Heh, and not just any wave, but a spinning one like a micro toroid, whose magnetic flux effects give the impression of gravity waves and thus the reasoning of being a particle having mass... ;)
giantkiller
Like a sand storm... or schools of ocean fish.
We see the wind because of the particles. We see the pressure wave because of the 'blowing around'. So is a sand storm, wind or sand?
Pretty silly, huh? :D
--gaintkiller
fcpeace17
Quote from: -[marco]- on October 20, 2006, 02:50:04 PM
it isnt much but hey im glad this worked :)
its a grounding issue.
whatever you do the flow will always seek the way to the ground.
if resistance to the ground becomes less the flow becomes bigger.
if resistance is too high it will jump to anything made of metal not grounded so not connected to anything.
im looking at this from the wrong side.
i am at the end of the powerline wich runs high above the ground using the earth as retour wire.
the man himself stood at the beginning of the powerline almost next to the generator.
i donk really know if he saw it with the ac or the dc but the dc system they used then differs from what we use now.
so tomorrow im going to do it the other way.
there will be not one single ac connection to the earth involved.
im suspecting too see a whole diffrent thing.
its also frequency sensetive.
i keep saying it.....stevens coils are also not grounded.
marco
It may just be this computer but that file does not seem to open.
Jason, i thought you might find this helpful... The volumetric sizes of the structures are also slightly different so that the secondary radiation emitted therefrom at resonance interfere with each other producing a beat frequency radiation which is at a much lower frequency than that of the incident radiation and which is amenable to conversion to electrical energy.
starcruiser
Marco,
Try to halfwave rectify the signal source to make it pulse DC, this should improve the output. I use car ignition coils to make HV for some experiements and I use a GM control module to avoid the negative pulse from the signal generator.
Added:
I also use a small 12 car battery to power these experiements to avoid the grounding issue as well as the current requirements of some of them.
Carl
Regards,
Carl
