The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
rensseak
Hallo to all,
today i made a test with what i'm thinking how it works. unfortunately the wire gone out so that I could not wind the other ring. I used a 6V Pb-accumulator to produce small sparks and it shows me a flashing light emitting diode. it gives a better result when the anode of the diode is connected to the +pol of the accumulator.
vielleicht ist es ja m?glich das SM mit dem magneten einen art funkeninduktor ansteuert. das kabel f?r den ring ist ein lautsprecherkabel mit gen?gend d?nnen dr?hten, die aber leider nicht einzeln voneinander isoliert sind . war auch nur mal so f?r einen schnellen versuch gedacht und das ganze ist auch nur zusammengewurstelt, ich gebe es zu. leider habe ich keine messger?te um genaueres sagen zu k?nnen.
regards
Gru?
Norbert
oouthere
Mannix,
Please ask SM if one compass is placed slightly above the coil and another placed slightly below the coil if both compasses will rotate in exactly the same direction, in unison, and in timing.
Thanks,
Rich
hartiberlin
Here is a page 262 scan courtousy of Jason Owens from
the Valve book !
hartiberlin
When I understand it right, "kick" means in this interpretation a mechanical jump
inside the earth field, but this is just a magnetical caused mechanical movement
and not an electrial induction pulse.... so this is probably not the effect we are looking for...
Regards, Stefan.
hartiberlin
Hi Lanca,
normally we have Barkhausen jumps only in Iron material, if I remember
correctly. But this is a tungsten wire in a valve...
