The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 60 Guests are viewing this topic.
giantkiller
Quote from: giantkiller on October 22, 2006, 12:26:42 PM
In looking at the clear picture, 10in spool. SM10? It would be a plastic, Right? Pop metal or aluminum wouldn't be a good air coil. Steel, that is an RFC. We would have to hear him lay it down on something.
1 layer of coils. looks like 4, looking down through the spool you can see across another winding. All physically looks like 16g pair speaker wire, look at the one in front. Remember, he worked in audio. The coil on the right could be magnet wire, but zoom and look at the physical side pattern. It looks like the front windings. The lighting could be wrong. The one across looks the same. I would say there is another by his fingers. White leads look like they go into the windings.
Where the meter leads touch, looks like where the spool crank handle went. And underneath that one can see 2 white leads each connected to some kind of bundle. The parallel / serial connections posted earlier?
And once again, there is a lumpage inside the ring, under his thumb.
@tao, yes! a clear video would be an immense amount on formation just through things moving to change the angular perspective.
Is this a new or old picture? Is the coil(cat) finally out of the bag? Biggest question yet?
And since we see that this working device is minimal with one layer, OOOOOOwEEEEE. He did stack them then to produce more!
@mrd, don't know if you saw this already. I did the best I could to rip it apart from my view.
@cliff, thanks.
--giantkiller
gn0stik
Well folks the basic structure and function of my site is up and running smoothly, this forum has picked up speed over there, and it's moving along quite well. the main discussion thread is general sm-tpu discussion. There are several other threads as well relating to kicks, coils, etc. so on and so forth.
@Tao, I have reset your password to test the older user's accounts on the new forum, email me gn0stik@gn0sis.com so I can give it to you. it works fine.  ;D
@ others who have been using it, I have fixed the image posting bug, the profile bug, and quote bug. All of which worked but were annoying to look at. All is well now.
otto
Hello all,
maybe a little help from me.
I hope you coilwinders have made your coils like Tao posted the pictures. He got this pictures from Mannix/SM.
@Dave
thanks for the wiring shematic. I have now a strong spinning magnetic field.
At low frequencies (5-10 Hz) I have on my scope pictures like J.L.Naudin in his parametric amplifiers. Also at low frequencies my power supply gets nuts. The voltage is very unstable (8-18V) because of the back EMF from the coil. Of course at higher frequencies the power supply voltage is more stable. Now I can play with frequencies.
At 8V DC on my power supply and 10 Hz from my square wave generator i have 25 Vpp on the coil that is wound all around the TPU (not collector coil). My input current from my power supply is 1,8 A.
On my radio I can clearly hear the pulsating signals (all frequencies) from the TPU all over the AM so I think I have a real good transmitter. The signal is very strong. When I shortly touch the collector coil with this 25 Vpp I have on the collector coil a really large spike. I will today play with the setup to see how to feed this 25Vpp into whatever to get something on the collector coil.
Otto
mrd10
Hi All,
I remember awhile ago, and this can be easily reproduced or replicated, If you have a home alarm system, with infrared sensors, try this, remove the cover of the infra sensor and see how far you can trigger it, I bet your bottom dollar, that it will only trigger a with your hand swaying a few inches away.
Now put the cover back on and what happens? its like a magnifying perspex/plastic, it will extend the sensor a few metres.
Now theres an anology if i ever can think of one.
we cause a rotating field with the aid of magnets = (Magnifying perspex/plastic) this field gets induced into the coil that we originally get the signal or signals from, and builds up. Once we have this rotating field with aid of magnets, were home and hosed, its as simple as that, its the kicks SM was talking about, smaller kicks being induced into bigger and bigger kicks.
All we need to do is tune the thing into a frequency, now that being schumans or earths magnetic field, or whatever you like to call it.
;D
Lets start here, i think we will be impressed on what we will find.
Dom
