The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
otto
Hello all,
@Tishatang
I have 3 collector coils with 1000 (yes, one thousend) wires each  and arround each collector coil 180+180+180+140 turns (this 140 turns should be also 180, ok I know) 0,22 mm wire (680 turns)of the control coils. Around all of this coils I have wound another coil with a few hundred (I forgot to count) turns 1mm wire diameter. The best thing is when I pulse my upper and bottom control coils the signal is 20Vpp on the 1mm wire coil but when I pulse the top and the, so to say, center coil, the voltage on the 1mm coil is much lower and that means for me that the diameter of the TPU AND the height are very important. On the collector coils I have, I think, 10Vpp. The freqency on the collector coils is different than that one of the control coils.
The control coils are connected as Dave showed us for the spining magnetic field and I think this is ok but I have to try to pulse the control coils in ways. 90? phase shift or one coil in one direction the other in reverse and such things.
Please look at Tesla patent no. 390 721. Very good drawings for us.
Otto
mrd10
Hi All,
Again read this url:-
http://www.arar93.dsl.pipex.com/mds975/Content/aerials1.html
From Url:- Ive just taken bits and pieces, note important bits in bold:-
....The circuit for a loop aerial could not be simpler, being a spiral loop consitsting of 10 turns* of
7/0.2mm 'hook-up' wire wound on the 40cm former, and a tuning capacitor to resonate the loop aerial at
different frequencies. ....
A Loop or Frame aerial is a wonderful tool to assist longwave and mediumwave reception....
....not only will it dramatically 'boost' the signal received compared to using a portable radio's
internal ferrite rod aerial ........
..... the loop will tune very sharply to the required frequency will rejecting all others........
.... The bigger the area of the loop the more signal it will collect.....
.....The radio is simply placed in the middle of the loop and the signals collected are transferred to
the radio via its internal ferrite rod aerial.........
Now I'm convinced that this is a very important part of SM's device, all SM's devices are based on two ring aka LOOPS
Tune this to 7.8hz earths magnetic field......has anyone tried this yet?
Sincerely,
Dom
mrd10
Heheheh a friend posted this to me:-
c=f x lambda
where c = speed of light . ie 3 x 10^8 m/sec
and f = 7.23 Hz
then what is lambda
I.e. 300000000 / 7.23 = 41493775.933609958506224066390041 meter Antenna!
41493775 meter Antenna!
Ok so then that second unit his got, maybe just solid plastic, and the fine coils on the bottom part are two tuned cct's
one is 5000hz and the other is 5000.0078hz, and when these two are combined we hit the earths magnetic fields resonante frequency.
This then is induced like a vortex within the other coils setup inside the rings.
The magnets are to a means to an end
Well I guess thats a starting point
Sincerely,
Dom
mrd10
Phew Dave,
You seem to know your stuff. I understand what you are saying about the collector coils in the centre, but what if we look at this at a different angle for the moment, now sorry for my simplistic view.
The collector coils in the inside of the rings are just there to create this jet turbine or rotational field, like what you have already demonstrated, i.e we are not concerned with that part being the tuned cct, the tuned cct is the finer windings that you can see on the bottom ring, at the bottom. I.e the coils are just there to amplify and increase the turbine effect, this then is induced into the larger winding you see just above the finer winding coils, once this all starts off it's like feeding itself.
Lets keep each system seperate and they have all seperate functions, but when used together, its like a generator,
I guess the easy way to look at it, is hydro electricity, the energy were tapping into is the running water which drives the turbine. The turbine is just one part of the system, then that turbine drives a shaft which is connected to a generator which creates electricity.
So the sum of all the parts makes it happen.
Does this make sense?
Dom
mrd10
Thats cool Dave,
I wasn't implying you knew everything, I think the best way to learn at this stage is to build on what we know so far.
1)theres a tuned cct
2)theres a rotational field
I could concentrate on rotational field for the moment, and see what happens when i inject say 7.8hz into it, like you setup with the 2 coils, I just need to wind four of them and connect them up in series, then wind another coil and place it near by to see if we get induction happening into that coil, if we do, we have part of the puzzle figured out.
The other part is the tuned cct.
To cap on what you just said, It's like my friend was trying to explain to me tonight, and i put an anology to it, its like waves in an ocean and you get hit by 7.x waves every second.
I'm sure we will findout more as time goes on. It's a learning experience
Dom    ;D
