The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 42 Guests are viewing this topic.
mrl
Well ? I've read about the first fifty or so posts on this device.
Here are my thoughts.
When a sudden (short) DC pulse is passed into a wire you will get a radiant event as noted by Tesla.  This radiant energy will move out radially from the wire in all directions thus super charging electrons.  The intensity of the radiant event is proportional to the voltage pulse applied and its abruptness.  However, you can use less voltage and more wire either wound as a coil or laid out in parallel.  This, I believe, is what Mr. Mark was talking about.  The thing is, the radiant event is lost if it is commingled with current flow.  John Bedini noted this as did Telsa.  John's device cancels out the current induction using bucking fields in coils.  In other words, a DC pulse is applied to one winding to create the radiant event which then tries to induce a current in another winding, but that current is then pumped into the base of transistor through a sensor winding which then energizes a bucking coil that cancels out the magnetic field that is created by the first coil.  In other words, only a small amount of current is allowed to flow in your radiant energy collector winding by induction.  John is in fact invented radiant distillation process, where most of the radiant energy is allowed to get through, but very little current.
I think what Mr. Marks device does is kick out a radiant pulse which then energizes collector coils that then start to resonate at their (two) preferred frequencies.  There are at least two frequencies that create a beat frequency which rotates around the toroid.  Mr Mark's controller is designed in such a way so as to stay off the exact critical frequency so it won't run away.
I think to capture a radiant event you must try and avoid educing current flow in your secondary collector windings by the primary (Tesla's air core transformers did this).  From what I understand I think Mr Mark does this by winding the radiant windings in a toroid but then winds the other coils at ninety degrees around the toroid windings.  This would avoid inducing too much of a current flow in the secondary windings thus leaving these winding to soak up whatever they can in radiant energy.  When the system is tuned to the cosmic radiant beat frequency, and is in sink with it, you then get a synergistic effect.  Henry Morey tuned his system to this beat frequency using multiple stage radiant amplifiers.  The system would start to amplify the oscillations until they reached an amplitude that was above a predetermined floor.  Anything above that ?floor? was used to run a load.  Mr Mark's device may work on this same principle.
Anyway, that's my four cents.
mrd10
Hi Gaspo,
Do you have pics of how yours is wired up? I'm in Australia also.
I'm just going back through posts, from Otto:-
yes, look only at the exiter coil and the transformer coil.
The exiter coil loosk like my control coil and this is ok. What I will try is to feed the signal from this transformer coil (my 1mm coil wrapped all over all coils) to my collector coils. I see this transformer coils as outputs. I know I will see a little spectacl.
The exiter coil to me looks like a small generator/motor
I have only connected only the exiter (control) coils. 2 of them. No fase shifting in this moment. The kicks are great. The frequencies are low from 2- 50 Hz, I think so and from 50kHz up. At this frequencies is the best signal and the lowest amperes. I didnt measure the frequencies yet but I will. Input from power supply is 8V/400mA and from fignal generator 4V in mA.
Again The exiter coil to me looks like a small generator/motor, but Otto mentions his connected ctrl coils to it.
sorry. When I was connecting the wires on the collector coils there was NO INPUT at all and as I said the magnetic needle was slowly spinning!!
Dont worry I think you understand me well. Again: NO INPUT, needle SLOWLY SPINNING!!
I guess we will have to findout what the exciter coils look like, perhaps he has like a crystal radio setup and this is the input to the one i drew.
END
Also Perhaps Otto connected the wires together, i.e the ones that look like transformer
The transformer and large looking tansformer at the top of the page are connected the same way, just that the transformer, looks like it has two sets of coils, theres finer one on bottom and what looks like a larger diam coil around it.
Again i guess we need pics and that way we can have some direction.
Dom
giantkiller
@All,
Thanks for the replies.
I see in the patent 390,721 that in the transformer part he, again has opposing coils end to end and drive them in pairs across from each other. Well if we use DC pulses the BEMF from the first pair will be pushed/added with the second growing field. and them on to the next pulse. Is this thinking wrong?  I am working on a graphic avi to show this.
--giantkiller. Sometimes simplicity is just too open for stupidity.
mrd10
Hi Dave,
Could you try something, do you have a function generator handy? If so could you try plugging this into your current setup and see if you can get compass spinning as it is?
My feeling on this is that Otto has some sort of coil plugged into the toroid, and this maybe picking something up and feeding it into the toroid.
Dom
giantkiller
Hi Dave, Dom,
I hate to task anybody but,
I am looking at the diagram of patent 390,721. It looks pretty obvious but is everything 180d?
Thanks,
--giantkiller
