The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
giantkiller
Hey everybody,
I have dug into this patent 390721 pretty deep. And thanks to emdevices, MRd, dave, jackfrost and others for the answers.
I honed in on the the transformer part and it is very bizarre.
Pic attached and stats. Web link is http://www.pat2pdf.org/patents/pat390721.pdf
K = p1 large wire, large turns output
k1 = p large wire, large turns output
m = n1 fine wire, many turns
m1 = n fine wire, many turns
The output coils are:
The K pair, each are wound sequentially in the same direction around. Serially.
The k1 pair, each are wound sequentially in the same direction around. serially.
@mrd
The input coils are:
wound in pairs opposite each other and each pair is cross coupled so you have n and s switching side to side and top to bottom. Instead of circular! Is Tesla hiding something here? Experiments will have to be made!
He also stated he prefers to drive them at very high speeds. This looks a Tesla coil powered in reverse. If you drive the smaller wire, higher density coils with high freq then that will compensate for the lower amount of windings on the output, right? But the Nx configuration is totally batty. But powered hard or fast enough wouldn't that cause vibration?
And the core looks like it is made up of strands. And yes Dom, very much SM coils! And per his quote 'Some in parallel and some in series'. More like a hint to a puzzle than what I had previously thought. And why shouldn't it be. The guy is ellusive. A game player, no? And on that note: after my last Eflame to the readers, Mannix included, we get an astonishingly clear picture of SM from Mannix. After 9 months? Twisty...
What if patent 390721 does work normally and is a diversion from what the transformer really does?
Our lives today run on only a potion of Tesla's ideas. But all of his ideas work!
--giantkiller. When will the cat catch the mouse? :'(
mrd10
Quote from: giantkiller on October 28, 2006, 12:24:56 AM
Hey everybody,
@mrd
Hi GK,
I saved the 721 patent as jpg format from that huge pdf i got, its in 4 parts, I will have to go read it myself. Just one quick question GK, what,s those rails hanging of the smaller transformer on the bottom, they got circles in the middle of the tracks
tishatang
Hi all,
Here is a link to a Moray speech.  A good read!
Gives hints how radiant energy works, spilling over to next stage, and makes note of backsurge of capacitors.  This was also referenced by Aspden in one of my earlier posts.
http://merlib.org/node/1673
The gems are scattered thruout that apply to our search here.
Tishatang
giantkiller
@mrd
Those are two rails of light bulbs in parallel with a motor. The patent states that either can be run. See what I mean? It is almost childlike. Using a patent to retell something already done. Except the configuration of the transformer. That is the only odd thing. But I will say this that this same configuration of 3 stages of coils is in the Tesla museum in Belgrade. Only the coil configurations are straight forward. Well, from what I could see in the movie.
-giantkiller. There is a mystery afoot!
RS
Quote from: kames on February 23, 2006, 07:52:15 AM
Hi Lindsay,
You are absolutely right. The inner coils are the part of the control unit that help the other coils to collect. Does it mean vortex? Maybe, but not convinced. The absence of such control unit in some (not all) other torroidal power units in the videos makes me think that the idea is simpler.  When I said ?rotating? field, I actually meant standard rotating field, like in the electrical motor. I didn?t mean vortex. Stefan reminded me that it might me a vortex. Agree with Stefan. But I don?t think the idea of the vortex is used. Even if I am wrong about the vortex I fully agree that the vortex can actually multiply the ?kicks? under some conditions.
Regards.
