The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
tishatang
Hi all,
I found this site yesterday off a link on Keelynet.  I have read thru this thread only once, but I got so excited, I thought I would jump in.  I didn't want to be left out of this bit of history.
I am a retired musician, but I have always had an interest in science.  Not mathematical, but practical.
In regards to the initial kick, reference was made about Tesla in the "Lost Science" book.  A better reference in the same book was about T. Townsend Brown on page 237 when he observed the heavy cables jump up when a plasma tube was demonstrated when he was a young lad in school.  He observed the cable jump up when first energized, and a second jump when the current stopped.  The first jump was bigger than the second jump.  This led to his career path and dream of creating a spacedrive.
When I studied electronics, it was vacuum tubes.  The class project was for each student to build his own 5 tube superheterodyne receiver.  In a superhet, a strong frequency is beat against the weak radio signal.  This creates a third frequency which is the difference or the sum of the  two frequencies.  This signal is much stronger than the weak original radio signal, and this is what is amplified downstream.
Here is my take on what Steven Mark has kindly decided to give of his time.  Of course I am just a musician, I could be way off target?
The heart of the generator is three coils next to each other.  The primary coil is part of a tank circuit that is tuned to oscillate around 180,000 hertz.  This is the supposedly natural frequency of magnetism as per Coler device or MRA, if my memory serves me right?
When the magnet is inserted, it provides the initial kick to put this primary coil into oscillation.  The secondary coil is part of a tank circuit that is tuned just 7.3hertz lower or higher than the primary circuit.  The two higher frequencies will beat against each other creating this third frequency of 7.3 hertz.  This is the frequency of the third coil tank circuit.  The natural Schumann resonant frequency reinforces this cycle, which in turn reinforces the other two coils because they are all closely coupled. The slightly out of phase circuits create a virtual wave that chases itself around the torus creating the magnetic vortex.   Power is taken off the capacitor of the appropriate tank circuit.
I hope this helps?
tishatang
Elvis Oswald
Put the whole thing in a gyro and it'll go anywhere :)
Elvis Oswald
The whole thing about using two frequencies to net a third sounds reasonable.  And certainly the theory of the position of the magnet makes sense...
I really like this theory. :)  But like all theories it must be tested... and towards that end... allow me to play "devil's advocate" :D
If the third circuit resonates at a frequency that pulls energy in from a resonate cavity (between the earth and the ionosphere) then why isn't it charging all the time?
Doesn't the theory require an assumption that the third circuit is capable of pulling energy from "the aether" - does that mean it should be able to work without the other two circuits?
But that is a mute point for now.  I only bring it up because it is the essence of the theory.... that the thrid coil pulls energy from something.
Alsio - are we sure the circuits are tank circuits?  In a resonate tank circuit, the reactance of the coil should be eliminated.  This is not what appears to be happening with the device - i.e. the gyroscopic effect.
Maybe caps are in series with the coils?  This would draw as much current as possible.
tishatang
Hi all,
The third resonant frequency (Schumann) is too weak to overcome losses by itself to sustain resonance.  Or, if it could sustain resonance in a circuit,  as soon as you tried to extract power, it would stop.
Let me explain again the superhet principal that made radio come of age from the crystal sets.
The weak radio station tuned to receive is mixed with a stronger frequency in a tube.  When you mix two frequencies together, you create two additional frequencies.  One is the sum of the two original frequencies and the other is the difference between the two frequencies.   These two frequencies are stronger than the original signal because of the strength of the added frequency.  In our case we know to look for a frequency of around 7.4 hertz.
The first coil is finely tuned to 174k and we really can't mess with it.  The third coil is finely tuned to 7.4 hertz and we can't mess with it.  So, the control must come from the created frequency of the second coil that we energize with the battery of the controller.  The controller is a varible capacitor the detunes the resonance of the second coil.  The first kick start is the magnet, the second kick start is the battery powered second frequency.  The third kick start is the shcumann resonance, even though weak, is just enough to build little by little up to usable power.
There is a forth coil, which is the fewer heavy turns for output.  I assume these coils to be all flatwound and stacked on top of one another.  Does anyone know for sure if the coils are torus wound or flatwound?
Does anyone catch a glimmer of light at the end of the tunnel?
Tishatang
Elvis Oswald
A very bright light indeed.  I hope it's not a train.  :D
Seems easy to test though. :)
The 174khz circuit and the (166.6khz or 181.4khz) circuit create a frequency of 7.4hz which is picked up by the 7.4hz coil.... and that powers it and increases it's "size" to something large enough to pick up more of the Schuman resonance.
Do you think the magnet is needed?  Why not just use another battery?  Then you could use any two freq. that were 7.4 apart.
