The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
giantkiller
Quote from: mrd10 on October 28, 2006, 08:55:47 PM
@GK,
Nice graphics on TPU operation, regarding the Tesla patent 390 721.
@Coil builders out there, has anyone tried putting two sinewaves into the drawing I made of the coils?, thats this one:-
Hi Dom,
The drawing you have is the output connections. What my flash file was depicting are the N/S fields and how they are arranged when the communtators conduct, which are dc pulses.
@dave, I need verification on what I showed the fields are like. Does the swf seem plausible?
Thanks.
--giantkiller.
giantkiller
Quote from: Kosh on October 28, 2006, 10:45:56 PM
Quote from: Mannix on October 28, 2006, 10:22:51 PM
I will add that Steven has said that there were many different configurations and combinations of wiring that gave a result.
Has an body considered the "interactions" between the transformers on about page 3?
Is there a possibility that the out of phase transformers have an electrical property that is not normally exploited?
It is interesting that I was thinking exactly on that interaction when I read your post...
Those bifilar windings may be a combination of control AND collector coils.
That way you would have four transformers interacting together.
Does everybody understand the implications of high voltage high current and high frequency and the effect that it has on body tissue?
I did feel that effect right on my hand more than once. It hurts...badly...
Kosh
That is what I have on my Big coil. It is also iron core. I have driven it sine I got my controller fixed. I need to up the freqs on the clocks still. Probably today.
--giantkill. Honorable mentioned.
mrd10
Quote from: ctglabs on October 28, 2006, 03:28:39 PM
Right, there is four coils on the open TPU.  If you watch and pause you can SEE IT.  I have provided it here for you.  It looks like they are all bifilar, but in any case, there are 4.
Hi Dave,
this makes sense, and where he places the magnets on are his tunning cct, I believe anyway. I'm trying to understand what bifilar means, and I have been reading from this url:-http://en.wikipedia.org/wiki/Bifilar_coil, looks like 4 types.
So to me he is probably using parallel, since you want to increase the magnetic field, but has probably connected them as per the Tesla transformer.
This setup is very similar to his first one which shows he places a single magnet near an inductor. And a good guess is that the finer windings that are wrapped around maybe one section of the ring is where the high voltage is collected...
Hmm this does make sense, so if where he places the magnets on are resonating at 7.8hz, and he feeds this into the ring coils, and causes a rotational magnetic field where the finer windings pick up, YES THIS DOES MAKE MORE SENSE
Interesting that the bifilar coils are quite large.
I tried enhancing several images with sw called topaz, here's one i did:-
Good work Dave
mrd10
One question I have though, to anyone that can answer it,:- If I use one copper wire and just run over and start again, would this be like parallel bifilar?, example like this link shows:-  http://theverylastpageoftheinternet.com/howto/windingcoils.htm
so you start from the left, coil it till you reach the right, then put fine tape over the first coiled and then run the wire back to the left and start again.
Sincerely,
Dom
virus
Nikola Tesla explains that a standard coil of 1000 turns with a potential of 100 volts across it will have a difference of 0.1 volt between turns. A similar BIFILAR coil will have a potential of 50 volts between turns.
In that the stored energy is a function of the square of the voltages the energy in the BIFILAR will be ...
50 squared / .1 squared   =   2500 / .01   =   250,000  times greater than the standard coil
From Teslas bifilar coils patent.
The mere fact that SM turns the coil upside down to shut it down, means that when replicating it and one winding is the wrong way round or connected wrong it wonââ,¬â,,¢t work.
SM understood the mathââ,¬â,,¢s or if you like the theory around this concept, thatââ,¬â,,¢s why he could built then in different arrangementââ,¬â,,¢s,  size, etc. and they worked.
Virus
