The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
mrd10
Hi All,
It's still great to see how much is going on here in our posts. So many minds coming together.
Ok I did something today, I think alot of people here should do, because I believe, and yes I'm using that word to 99% certainty, that EMdevices is on the money with the kicks being resonance. This to me seems most plausible.
So if your looking for kicks , look for resonance.
Do this simple experiment, get two tunning forks, say the letter 'E' which is 329.6hz, and get an empty tin can, which we will be using as a medium. Now hit one of the tunning forks only, and put them both on the can, the other one you didnt hit will start resonating at its frequency.
Now the above experiment is just a simple experiment, now think of the earth as the medium, and this medium have frequencies at play 24 x 7, all we want to do is collect these small kicks that are happening all the time and magnify if you wish into larger kicks.
I can't see anything but this as the exlanation, and the toroid is the other part of the magic.
Thats what I've got to say, there's something else to while i was writing this, and maybe even simpler, Its to do with the two cans and a string we all come to know, but probably havent thought anything more from it:-
http://www.howstuffworks.com/question410.htm
Sincerely,
Dom
mrd10
This is what I want you to understand from the link i just gave you
Therefore, the bottom of the second cup should start to vibrate back and forth just like the bottom of the first cup is vibrating,
tishatang
Hi all,
In regards to the inertia and gyroscopic effects, I feel that we are talking scalar waves here.  This is something I posted earlier, but this thread has become so long that I thought I would mention it again now that we have an idea about the arrangement of the coils.
I am no expert, just a retired musician, going to be 70 next month, but this may be important?
A scalar wave is a close cousin to a gravity wave.  They both go thru everthing and cannot be shielded.  I feel scalar waves also cause the inertia effect.  I definitely felt a tug in my hand when my son energized a mobius coil he had just made.  Scalar waves are supposed to be created when magnetic fields cross at 90 degree angles.
One could look up Smith coil at Rexresearch or Naudin.  It is the junctions when the current returns and crosses at 90 degrees that creates the scalar wave.  In the TPU, it happens when the opposite rotating field collide.  It seems colliding magnetic fields somehow transfer normal everday electromagnetics into unknown scalar territory.
In a mobius coil the wire is folded in half.  The looped end is placed in a vice and the other ends are placed in a variable speed drill and the wire is wound up like a rubber band until the wire is twisted into a 45 degree angle.  Instead of a few cross over points like a Smith coil, the entire length of the twisted wire is capable of generating scalar waves.  I don't think it is necessary to do the mobius knot.  Just fold the wire in half, or two wires if you want bifilar, and twist in a drill and then wind your coil.
I don't know if SM twisted his wire coils this way.  If not, this technique might produce a more powerful TPU?
Energy wants to flow in a spiral motion.  Look a whirlpools and tornados.  I was always amazed how dirt devils could just start up out of nowhere and then quickly die down.  Something would happen to disturb the equilibrium, and they would just spring up and out of relatively calm air, their velocity would pick dirt right off the ground.
The TPU is disrupting the equilibrium the same way as a dirt devil forms.  Since the energy wants to spiral anyway, once it starts, it builds and builds.  We just want the keep the dirt devil nice and small and not turn into a tornado.
Otto,
I think your occasional spike on your radio is important.  Your coil's resonant frequency is close to a harmonic of the elusive energy we are trying to tap.  And, possibly as in a dirt devil, conditions are briefly triggered for your passive coil to energize?
I want a TPU birthday present!
warm regards
Tishatang
Thaelin
EM:  It was said that you do not want to zero in on resonance. That would mean that you would need to be slightly off. What would using two frequencys, one above and one below resonance. Using two harmonics of the correct resonant should make the torid then be "close to resonance"
Marco:   I still keep going back to seeing this a poly phase motor minus the rotor. The rotor couldn't keep up with high frequency anyhow. The fields are there all the same.
All:   This could be wired as a 3 phase with each pair of 180 degree coils being injected with one of the frequencys with the other ends tied together. This in my thinking would cause the collision of frequencys and that making them augment. Since I only have one signal gen, I have not been able to test this out. I did use a cap across the second leg and did get a reversal of the sine wave on both. When feeding both segments into one channel the scope showed double the output. It does need to be a fairly large cap, using 1uf from a microwave right now.
Now for my stumbling block.   So far I use a signal gen to initiate this action, in the tpu, there is no such thing. I am still stumped on how to make an input strong enough to fire off the coils. I cant in my mind fabricate such a situation yet. It illudes me and I should be able to figure this out. An LC will oscillate whether you have anything tied to it or not. A wire 80 meters long will be picking up all the traffic in the said band whether or not its connected to a receiver or not. Yet, I cant seem to get one to oscilate strong enough to be used.???????
sugra
archon79
This moves so fast that most here don't bother to notice what is happening in the other threads.
Someone posted a schematic of a device which seems to be very similar to the SM device. Its called the Rene-Rator
http://i125.photobucket.com/albums/p51/renerator/freeenergy.jpg
"Every second wave, marked red, coming from the output coils is the actuator pulse for the 'input' coils to block the magnetic field of the permanent magnets. The permanent magnetic field retracts from the core inducing a current flow in the output coils. After the input 'pulse' is gone, the permanent magnet will restore the magnetic field in the core, causing a 'back-emf' in the output coils."
The only link to this rene-rator is found here, and they claim it is based on an even older design from 1871.
http://www.zpenergy.com/modules.php?name=News&file=article&sid=2087
