The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 36 Guests are viewing this topic.
mrd10
Hi tishatang,
You beat me to it, thats what Iwas going to mention next....--COILS
I'm going to build my unit around 2nd prototype, because we can see the rings and the coils. It is wound bifilar, this makes it much more powerful, and was the way Tesla did most of his windings.
Now I'm even considering doing it trifilar, and this would be even better, but I'm not sure how to connect them , so I've drawn a pic, and if any coil winders can help me in how to do it, You could use my drawing and just make the modifications, note I've added the bifilar ones, which is ok.
Sincerely
Dom
mrd10
Hi Sugra, have you been using magnets at all?
otto
Hello all,
@Mannix
with the transformer coil I mean the coil that is wound VERTICALLY over all coils all around the TPU. I have wound it in 4 segments. I made my TPU like Tao showed us in the pictures. I think he said you gave him this setup.
@Dave
the control coils (2) are connected to the function generator (2 frequencies) one end and the other to +8V DC.
@EMdevices
NOTHING means that I had no waveform on the collector coil but I had a signal out of my function generator and +8V from my power supply. It looked like the coils are "blocking" the signals.
About the spinning needle
Maybe the needle was spinning because of my warm body or ... I didnt like this needle because it was soooo sensitive.
@tishatang
Im working on my TPU every day from 5 in the morning but I dont know if it will be ready for your birthday.
I can now "produce" this spikes heard on my radio. I take the ground connection from my scope and touch the collector coil and I hear a very loud bang. I measured this signals and they are 20V. Touching the collector coil with a screwdriver or metal nothing to hear.
mrd10
Oh another thing Sugra, SM is most likely using very effiecient windings, and hence amplifications are possible.
@Marco, now sorry for me to use such words as 'most likely' and probably , see youve given me a complex now on using these words, so forgive me , until we definitely know, im going to use these words.
Now I like to use facts before i post, and acouple of posts back i sent a link on bifilar electromagnet, which is twice as strong, than normal windings. So my next step is to wind the coils very efficiently, so anything small gets amplified dramatically.
This I believe will answer your question Sugra.
Try abit of reverse engineering guys, those early videos are a good guide.
Sincerely,
Dom
mrd10
Ok Marco, no problem, just I got a complex when i read your post, you prob got frustrated.
So here's my research so far based on facts:-
#2 cans and a string, connect two cans with string, tighten the string and talk in one and listen in the other. Proves Resonance.
#2 tunning forks , hit one and put both on a can, and you'll see the other resonate as well, actually take the one you didnt hit, of the can, and put it near your ear, you can hear the tone.
#About coils, Bifilar is much much better than single wound coils, Here's the experiment:- http://www.tesla-coil-builder.com/bifilar_electromagnet.htm
The above experiments are fact.
####About The Clear TPU that Lindsay gave us 91 volts output lighting 2 x 60 watt globes######
#bifilar is much more effective than doing single winding, and if you guys do a search on this forum you should find my drawings. I'm actually thinking trifilar, if anyone can post on how to do this, that would be great.
#Build the coil as per Tesla Patent 390 721 again you'll find my drawing which I clearly show how to wind it, and connect it.
Do a search for Tesla egg, in youtube and you'll see video demonstration in his home country. This shows the rotating magnetic field.
#The rings im going to use plastic, as I believe he is using, someone said it looks like those car set tracks, and i believe they are. They are to shiny to be metal. So to the toy store I go. To look for something similar.
#Now we build a very efficient toroidal setup, If I don't findout how to do trifilar winding, then I will just do bifilar.
#Tunning part with magnet, looks like he uses and inductor, which he places a magnet ontop of it, this isnt shown in 2nd proto, rather it is shown in his first prototype, and the inductor is toriodal.
The tunning part is something i need to experiment with, any ideas most welcome, I will try and get one to physical size he uses on the 2nd proto and first prototype.
My feeling with this is like setting up a crystal radio, with and inductor and variable cap, and output this to TPU, perhaps the magnets lock in the frequency, and gets tunning cct to resonate at the earths magnetic field, As someone mentioned.
Sincerely,
Dom
