The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
0 Members and 27 Guests are viewing this topic.
starcruiser
Regards,
Carl
starcruiser
@Dave,
Sorry to be absent  but I have been engaged in work related activities that has been taking most of my time so experimenting has taken a back seat. Fortunately these distractions have been resolved and I will be hard at it again.
I am still working on the crystal receiver idea, my local electronics store did not have the diodes I wanted to use in stock and had to order them. i should have them within the next week or so. I hope to have some promising results soon. I am very encouraged by Otto and Marco's results and I am planning to wind a new torrid this weekend to see what results I can obtain as well.
On a related note:
During my absence I obtained a new inductance meter and was checking the inductance of the coil I wound (the samll one for the tickler) and found it has only .0011mH inductance, I also checked a donut magnet I wound with some 26ga solid core wire on, it is a smaller coil and form about 1/4 the size and it was showing me .0023mH. Interesting effect the dounut magnet has on the inductance of the small torrid, almost doubling the inductance with 1/3 to 1/4 the windings. I did also try bringing a strong ceramic magnet near the larger one and noted it does affect the inductance by about .0001mh (increases it).
I will be trying next to pump a signal into it and see if / how this affects the resonance of the coil alone. Hopefully we can all get back on track here and build on the positive results Macro and Otto have had.
Regards,
Carl
mflynn44
From http://keelynet.com/interact/archive/00000321.htm .
The outer toroidal coil overheats and has no magic factors inside it
other than a length of the coil which is cut until resonance is
established. In the core of this outer toroidal coil is the instrument
package. A magnet is used and a resonance is established using the
mechanical (Lorentz) forces developed in the coil. The system pulses
with a DC component.
Tuning is a function of the coil mass and cross-sectional aspect ratio.
It appears an elliptical cross-section is required in the coil. The
converter package in the center of the toridal coil appears to be a
circuit to convert the pulsed DC component to AC.
This whole device is a low-voltage, low frequency, high-current form of
the high-voltage, high frequency, low current Moray device. Each system
has its good and bad points....
mflynn44
From http://www.keelynet.com/energy/markfake.htm .
The Stevens Device:
Energy from Coils of Wire and a Magnet
(this is the Markovitch device)...
For lack of any name, it is being called the "Stevens" device (Markovitch) .
dutchy1966
Quote from: ctglabs on October 31, 2006, 04:52:39 PM
Marco, lets say then as an ANALOGY that my bag of coal never runs out, it is an ever lasting supply like this "energy".  I still do not get more energy out than coal I put in?
IF I PLACE a water turbine generator in the sea, is it free?
Well, it doesnt cost me anything to get power.  BUT I dont get more energy out than the energy of the sea wave hitting the turbine.
My point is, what kind of situation can allow more out than in?
The TPU has no input.  It starts by itself.  If I dont put any coal in, I get nothing.  How does the turbine spin itself?
Dave.
Hi Dave,
I think it's not a case of MORE out than in. I see it as SOMETING unused by men in, and energy/electricity out, so basically it might not even be OU!! SM says that as well it's conversion not FE in the strict sence of the word......
BUT the resulting energy might be free to us because the source is all around us and unlimited.....
Dutchy
