The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
mrd10
Hi Dave,
I found that link, information on the elemental rods:- http://jeanyves.hervouet.free.fr/JapRod/,
I don't know how i came across this, but im glad i did.
@Kosh, you used bifilar windings, great. How did you end up connecting the 4 segments? are they in series, e.g
--c1--to--c2--to--c3--to--c4--, that is there all connected, or did you connect it as per Tesla Patent --c1--to--c3--,    --c2--to--c4--, which is two connected 180 degrees from each other.
So I don't get confused, the bifilar windings, they are your collector coils, and the control coil is you output right? and this is blue?
In Lindsays clear pic of second one, he has a finer coil wound around bifilar, which at this point i'm going to call that the output, and the bifilar windings going all around the bottom ring is the collector coil and the magnet coils are the control coils, Is this correct?  Because in your setup then your control coil isnt there, but your using pulses.
Just want to save some confusion guys, so we understand what all the coils are named.
Dom
mrd10
sorry i just read my post i mean your control coil is what your pulsing into the toroid. that is into the bifilar
giantkiller
Quote from: hartiberlin on November 01, 2006, 07:05:53 AM
Yes, the user Anbody
is Lindsay Mannix.
Here you can see his latest postings:
http://www.overunity.com/index.php?action=profile;u=1180;sa=showPosts
The last one was at:
October 05, 2006, 05:08:24 AM
I still have a SQL Database backup from yeasterday,
but I firsthave to find out, how I can read the postings
from it without installing a forum around it.
Does anybody know, if there is something like a SQL content viewer program ?
Thanks.
Regards, Stefan.
I use MSacces for the import the thread print to a 1 column db. Then I just do my sql that way. Slick trick that works.
--giantkiller
mrd10
Hi Kosh,
I looked at you pic again, so your control coil is the blue , because i can see that your pulsing this.
And your bifilar is your collector, hmmm
See I'm referring to 2nd prototype, the bifilar I believe in his is the one thats being pulsed, so we will call this the control coil,
The output coil is which is the finer wire is wound one segment around the bifilar, so am I correct its 180degrees, so like a transformer.
And the magnets which SM places ontop, is the ctrl coils, which are just underneath it.
Could you do me a favour and pulse the bifilar, but rig your bifilar coils 180 deg , i.e like Tesla Patent ---c1---c3--
--c2--c3--, pulse these two with different and same freq.
Wind another finer coil which is your output coil around one of the segments of bifilar coils.
Then see what results you get.
Dom
mflynn44
Quote from: mrd10 on November 01, 2006, 11:22:01 AM
Hi Dave,
... In Lindsays clear pic of second one, he has a finer coil wound around bifilar, which at this point i'm going to call that the output, and the bifilar windings going all around the bottom ring is the collector coil and the magnet coils are the control coils, Is this correct?  Because in your setup then your control coil isnt there, but your using pulses.
Stephan and all,
... 1 metre of lamp wire(twinflex) wrapped with thin insulated wire..it takes about half an hour. you will get sore fingers!
Drive the thin wire with low frequency sinewave and check out the result from the lamp wire!
I would not have expected pulsed high frequency from this setup.
Lindsay Mannix
