The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
dutchy1966
Quote from: ctglabs on November 01, 2006, 02:17:00 PM
Dutchy,
I guess you are right.  We can just measure the output voltage until its higest.  Then make some power measurements.
We can lower the frequency, but the coil wil get too large.
So, if this is the principle, why there is 5Khz pulsed DC output?  If he is using 5Khz, when on this frequency we are going to need 60 km of wire?  So, something not right.  Can it be two waves are send and they are slightly off so they dont add totally and over run, and they leave a difference of 5Khz.  As he says the frequencys are very high and are just a means to an end.
But for waves to add, we must have 100%.  But then if SM found some magic mix, who knows.  I will know more once I have these two white noise generators to mix.
Dave.
Hmmm, you could be on to something there but it has to be done so that all the waves in the loops end up at the same spot on the circumfence. I have to think that through....
Well I'm gone for today.....Let you know my thoughts on that tomorrow....
cu l8ter
Robert
c0mster
I watched this video again. http://video.google.ca/videoplay?docid=333661567309752927&q=steven+marks
Steven says repeatably that the electricity is 6000Hz. This video also shows two rings as opposed to a solid toroid. It's to bad that home video cameras in the 90's had such a fuzzy picture.
Comster
giantkiller
Dutchy,
Dave.
Hi all,
nice going,
I had posted something about this long ago about the magnetic interference of the 2 toroidial fields impacting each other. I was thinking about counter rotating fields but that won't get you the vortex action that Marco was contemplating. The difference might be, in the magnetic fields, a very aggrevated effect. The closer the fields the lower the difference. If the difference is what the coils are tuned to and make it the 7.8hz arena we could get away with a small collector? And I know some of this has been stated before by @otto, @dave, @mrd. The collector is tuned to 7.8hz or a lower harmonic and that is also the difference of the two freqs. Somebody stated prior the electronics must be easy to do the get the runtime specs. SM cranked out 6? of these of different configurations and they all worked? God, we gotta be close!
I could use some outside of this to hear what everybody thinks.
If we want to put the control windings in a ring and use the right hand rule of winding. We want the north pole to point in the direction of clockwise. With this, in all cases we have the current flowing through the control wires all flowing into and down through the center. We pulse the control windings in a clockwise direction.
So what we end up with is a clockwise, rotating magnetic field with the coil current all flowing through the center from the top down. This puts the field generation in sync with what the earth is doing or can be tuned or directed to do. Like a via duct. After all we don't make water run uphill and you don't try to nail jello to the wall.
And remember all the famous sayings of the nature that 'It can't be'. If you're stubborn that was your exit cue. Henry Ford was told that 'If a person goes faster than 20 mph they will die'.
--giantkiller. I, for one, am not dead yet!
mrd10
Hi GK,
Good analogy about the jello and pushing up hill, I've got an idea which i'm going to follow, and something the mflynn44 posted last night, look at the 2 ring version, i.e 91 volts, that Lindsay gave us, then Dave eloborated on, this looks to easy to build, so im following that one.
These are the combinations, im going with, and I will be building several, so I don't have to keep stuffing around with the same one:-
--c1--c2--c3--c4-- = bifilar = output/collector coil, wrap thin wire around this, which will be control coil, i.e were pulsing into.
--c1--c3--,  --c2--c4-- = bifilar = output/collector, wrap thin wire around this, which will be control coil, i.e were pulsing into
Now after looking at the clear pic, I noticed a white wire going of to the left of the bifilar coil, around the middle of the photo, this suggests to me that, the segments are wired in series, and they are only wound once around the ring, so again, I will build two as per above, now if you have image viewer and open up the image of this clear pic, zoom his hand till it matches roughly your own, then youhave a guide of how big the ring will have to be.
The thin wire that is wound wrapped in parallel with the larger bifilar winding.
Anyway hope this helps the Coil builders out there.
Sincerely,
Dom
mrd10
Hi Guys sorry,
I got this reply from Lindsay, and I hope he is still with us, again I should read my replies more often, Again I do apologies Lindsay, as I only read this recently, and please don't shoot me for sending this to everyone, If it gets us back on track, i'll be happy:-
Dom,
I think that you need to read the first half of this thread entirely and SLOWLY.
take your time  ther's lots there
You are dragging impatient ,new ones like yourself over old ground and slowing the progress. I am also worried that you have no experience with high voltage rf.
Other forums have started because of this and it is not just you. If you go thru it and accept that we do not and cannot learn all at once you may realize that many people have been here for 10 months and silly questions like bifilar and drawings that are wrong do not belong in the main thread.
The only people that are responding to you are those who are late commers and have also not read the thread.
the last post that you think was stevens latest was way way back... cut and pasted, so foot off the pedal uh?
Dont just post your imaginings.. do some experiments...get in the grove .. you write well.Make it work.
any way I gave you a direction which you completely ignored.
I admire your enthuesasim but slow down then catch up. Be a part of the solution.You will see what i mean if you do it.
I also screwed up by giving otto the wrong impression.
I have emailed him as well.
We will see what happens.
I will tell you something..I think that the reason that we do not have these devices is that when the inventor tried to explain..nobody would listen. They just wanted a free energy machine.
Lindsay Mannix
