The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
giantkiller
Quote from: mrd10 on November 01, 2006, 03:46:15 PM
Hi GK,
Good analogy about the jello and pushing up hill, I've got an idea which i'm going to follow, and something the mflynn44 posted last night, look at the 2 ring version, i.e 91 volts, that Lindsay gave us, then Dave eloborated on, this looks to easy to build, so im following that one.
These are the combinations, im going with, and I will be building several, so I don't have to keep stuffing around with the same one:-
--c1--c2--c3--c4-- = bifilar = output/collector coil, wrap thin wire around this, which will be control coil, i.e were pulsing into.
--c1--c3--,  --c2--c4-- = bifilar = output/collector, wrap thin wire around this, which will be control coil, i.e were pulsing into
Now after looking at the clear pic, I noticed a white wire going of to the left of the bifilar coil, around the middle of the photo, this suggests to me that, the segments are wired in series, and they are only wound once around the ring, so again, I will build two as per above, now if you have image viewer and open up the image of this clear pic, zoom his hand till it matches roughly your own, then youhave a guide of how big the ring will have to be.
The thin wire that is wound wrapped in parallel with the larger bifilar winding.
Anyway hope this helps the Coil builders out there.
Sincerely,
Dom
The c1-c3 combo is the config of the 390721 patent
mrd10
Yes thats right GK,
We have some experimenting to do, Looking at second proto again, he mentions that this is nothing to do with bifilar and way coils are wound, so he might be right in saying that.
I've gone back to first 20 or so posts, with correspondence between Lindsay and Steve and I will be reviewing this information again, we may have missed the point entirely here.
And I will try and listen
Dom
c0mster
@Dave
You got that right. Perhaps a rotating field is exactly whats needed. The hard part is finding the solution to the problem. I am changing gears with some of my thoughts and want to test different designs of coils. Hans Coler's device was using coils around plates that were interpreted as perhaps capacitors. When they cut apart the TPU it looks like 2 rings with filler in between. Correlation? Perhaps, only experimentation can show a result.
@Everyone
Keep up the good work.
Comster
lynx2000nl
Quote from: archon79 on October 31, 2006, 03:11:21 AM
This moves so fast that most here don't bother to notice what is happening in the other threads.
Someone posted a schematic of a device which seems to be very similar to the SM device. Its called the Rene-Rator
http://i125.photobucket.com/albums/p51/renerator/freeenergy.jpg
"Every second wave, marked red, coming from the output coils is the actuator pulse for the 'input' coils to block the magnetic field of the permanent magnets. The permanent magnetic field retracts from the core inducing a current flow in the output coils. After the input 'pulse' is gone, the permanent magnet will restore the magnetic field in the core, causing a 'back-emf' in the output coils."
The only link to this rene-rator is found here, and they claim it is based on an even older design from 1871.
http://www.zpenergy.com/modules.php?name=News&file=article&sid=2087
People don't wan't free energy it seems.
As i see it, this device works.
There is only a short pulse used to distort the magnetic field.
When the magnetic field returns to normal, the energy of it doing so, is collected. Hence, at the same time the energy is used to put a spike into the other circuit. This goes round and round. It looks like a resonating circuit which amplifies itself.
This is as simple as it can be. but nobody seems to see this?
giantkiller
Quote from: lynx2000nl on November 01, 2006, 06:05:38 PM
I had posted a flash file to show the rotating poles. But I realize that I need to show the fields.
I am working on the graphics right now. and then an avi.
--giantkiller.
