The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
giantkiller
Quote from: c0mster on November 02, 2006, 10:57:01 PM
Now I have 4 ceramic bars 1" * 1" that are not magnetized and 4 that are. The 4 that are are magnetized, are magnetized with north and south on the sides not the ends.  I need to router out the boxes on the ring to allow these bars to go through the plates. Just like the one TPU I posted earlier. Once that is complete I need to ponder how the coils are rapped. It almost looks as if the may be rapped lengthwise as apposed to around like a traditional coil. But I have seen posts here that show a possible solution.
Till next time...
Dude! You do sweet work!
--giantkiller. Now we blaze magnetically.
c0mster
Ahh thanks giantkiller  :)
All for science and science for all!
mflynn44
I've been doing some experiments with rotating magnetic fields with a feedback arrangment trying to get the "kick" described by SM and Mannix. I've just about come to the conclusion that my approach will never lead to overunity. I now think a rotating field is just incidental to the operation of the TPU or maybe there is no rotating field. Dave tells us "the power has to come from someplace" and, of course, he's right. Maybe it's necessary to think further out of the box. Looking back at some of the patents that morphed into the TPU has given me some new ideas. I wonder why most of the TPU devices are taped around the oval outer coil and painted black? Is it just to hide something? Maybe the tape is an active part of the device. It could be thin copper with adhesive on one side; they sell it in arts and crafts stores. This could act as an antenna feeding the device or a converter changing the output radiant energy into potential, or both depending on the internal structure. When radiant energy is converted into electricity the potential is DC. The input from the antenna comes into an arrangement of three coils which causes phase shifts and then the signals are recombined; this is where the "kick" comes from. The kick appears at random times but you can tune the coils for more or fewer kicks. The kick triggers the release of radiant energy; we're not dealing with electricity at this point. The radiant energy is collected and converted into electrical potential in the converter.
Dave, to answer your question. No, I don't know what radiant energy is. For that matter, I don't know what electricity is; I know what some people think it is. I do know radiant energy exists. What we call electricity is a subset of whatever radiant energy is. Radiant energy can be converted into electron flow (one form of electricity). Not directly, a potential (dipole) is created, the vacuum is ordered, and we can then have a flow of electrons from the vacuum through a load.
Dansway
I think this might have been talked about before, but there is so much on this thread it is hard to remember everything (no, imposible).
Take from the Keelynet "eScribe" list from 2002:
Hi Folks!
Along the lines of aether/zpe having dual properties such as;
voltage vs current
pressure vs vacuity
and a means of focusing the omnipresent aether/zpe background energy
into 'pressurized' or collimated HIGHER density beams that can be
intercepted to induce current or voltage which can be tapped,
Mike sent in the following excellent possibility;
HI Jerry,
I would like to point out another observation I have made which you may
have
made as well.  Have you noticed that the excess energy that comes in is
pretty well always 90 degrees from the flow of the catalytic energy,
i.e.
the arc?
Now, just think, induction is electrically 90 degrees out of phase with
capacitance, i.e. the current in an inductive circuit is 90 degrees out
of
phase with the voltage of a capacitance circuit, or vice versa.
This means, when I visually see it in my mind, that one is off axis to
the other thus it is not within the same time/energy domain flow of the
other.  This means that they have nothing in common and cannot affect
each other.
BUT, they can be made to do work and one can lead to the other.
For instance, suppose you wound a coil with a tightly twisted pair of
wires
which were not connected to each other at either end.  What you have
just
made is a capacitor.
Now take this capacitor winding and wind it around a magnetic core.  Now
take and wind another standard winding around this same core.  Now pump
the capacitor winding with an AC source.
The charge and discharge of the capacasitive winding will induce a
"magnetic" field in the core and cause a current to flow in the
secondary winding, BUT the capacative winding will NOT be affected by
the back EMF of the secondary
winding because magnetic energy, as far as I know, does not affect the
electrostatic energy in a capacitor.
Basically you have a one way transformer.  There are other technical
problems which have to be worked out and considered but I think you get
the gist of what I'm saying.
The reason one cannot affect the other is because they are 90 degrees
from each other from an energy prospective.
One coming down, and one going forward.  One can lead to the other but
not the other way around.
I think these properties are useful and can be exploited.  Remember the
Tesla flat wound bifiler coil.  Well, it was a high capacitance winding
with inductive properties.  One complimented the other.
Thus the coil exhibited very high voltage gain and Tesla claimed one
could start such a system and make it self running because of these
properties.
Mike
Regards,
Dan
otto
Hello all,
excuse me please for the next words you will reed from me but I cant be quiet.
So far we all have done a great job but we are making a step foreward and two backward or can anybody say he has a working TPU??
We have made thousand of posts, seen thousand of pictures looked at thousands of other sites that are great, but not for us.
How many of us has the equipment for this work and they are posting and wasting our time?
How many of us has made the coils for the TPU??? How many of us know what we are searching for??
We all are guessing. If, if, if...
Now you are asking what the hell..
I have 34 years expirience in electronics and I exactly know what we are searching. Im not a scientist but Im a television repair man from the good old times when we had tubes in TVs and I repaired thousands of them. Now Im in digital electronics for years, 10-12 hours every day.
Im telling you this because Mannix said Im on the right way (a little step).
Today I brought my scanner so I can post images what Im doing.
IM NOT THE BRIGHTEST BRAIN ON THIS FORUM SO PLEASE HELP ME!!!!!!
I dont want to wait 10 years to have a working TPU.
Let us work together!! from the beginning!!!
Please, guys who havent a scope, a square wave generator, and a multimeter be quiet(excuse me again for this).
Because this is a international forum and I see a lot of users are only reading and not posting ( I was one of them because my English is so bad) I think it would be very good for us that our ONLY German speaking friends can also work with us. Im speaking bad English (as you see) and very good German. So my friends feel free to contact me.
NO, NO dont think I want be a leader (chief). Im not a leader at work nor at home (I have a wife). I ONLY WANT A WORKING TPU!!!!
Im not so good in theories because I dont care much of it. Im a guy for practical work.
I will post drawings from the beginning of winding the TPU until we all finish with success.
