The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
mrd10
allcanadian
I was looking at comsters picture and the picture below it and this device looks like a circular parallel path device. Flynns parallel path device uses all the same components, in comsters pic the green elements between the circular plates could be permanent magnets ,one coil turns the magnetic field and because path is circular all paths turn like a domino effect, when the control coil is deenergized all coils then utilize the bemf. The trick would be to have the system act as a self regulating resonant system. Or possibly the small wire one post mentioned acts as the control and the rest are load coils, one load coil charges a capacitor which then activates the control. This seems more likely than the earths magnetic field powering a load.
any thoughs on this?
c0mster
Quote from: allcanadian on November 03, 2006, 08:29:19 PM
Interesting concept.
I will be wrapping the prototype with wire this weekend.
Then we can hook it up to a scope an try different configurations.
Comster
virus
For the interested
What to Look for When Choosing an Oscilloscope -
http://www.picotech.com/applications/oscilloscope_tutorial.html
Small tutorial
Virus
mrd10
Hi Guys,
I was doing some amazing reading, I call it amazing because from it I could re-inforce what SM has said all along.
Lets not get away from the fact that, the earth has a weak magnetic field, and the unknown that this field maybe on the move, like a huge electromagnet.
What if we developed a detector so fine , that we could detect this magnetic field and amplify it= we find the river.
Now think of a compass
http://www.howstuffworks.com/compass.htm
The reason why a compass works is more interesting. It turns out that you can think of the Earth as having a gigantic bar magnet buried inside. In order
for the north end of the compass to point toward the North Pole, you have to assume that the buried bar magnet has its south end at the North Pole, as
shown in the diagram at the right. If you think of the world this way, then you can see that the normal "opposites attract" rule of magnets would cause the north end of the compass needle to point toward the south end of the buried bar magnet. So the compass points toward the North Pole.
The magnetic field of the Earth is fairly weak on the surface. After all, the planet Earth is almost 8,000 miles in diameter, so the magnetic field has to travel a long way to affect your compass. That is why a compass needs to have a lightweight magnet and a frictionless bearing. Otherwise, there just isn't enough strength in the Earth's magnetic field to turn the needle.
The "big bar magnet buried in the core" analogy works to explain why the Earth has a magnetic field, but obviously that is not what is really happening. So what is really happening?
No one knows for sure, but there is a working theory currently making the rounds. As seen on the above, the Earth's core is thought to consist largely of molten iron (red). But at the very core, the pressure is so great that this superhot iron crystallizes into a solid. Convection caused by heat radiating from the core, along with the rotation of the Earth, causes the liquid iron to move in a rotational pattern. It is believed that these rotational forces in the liquid iron layer lead to weak magnetic forces around the axis of spin.
END
know note they say:-  No one knows for sure,
This above came about because I was reading about radiant energy, check the urls out, you'll find it very interesting
http://www.pureenergysystems.com/news/exclusive/2004/pylon_ambience/index.html
Pylon Ambient Energy Lights Fluorescent Bulbs
http://pesn.com/2005/06/14/9600112_High_Power_Lines_Shock_Umbrella/
Shocking Experience Walking Under High-Power Lines with Umbrella
Now under this title, I found something interesting:-
"A Little Experiment to Try"
If the tester's needle/coil is not sensistive enough, the voltage will drop to zero and the indicator will not move.
This line above made me think of the compass scenario above.
END.
And another interesting read:-
Radiant Energy -- Wireless Transformer of High Power Lines?
An Electrical Engineer who was in on the interview with West, mentioned that it is known that if a barbed wire fence, of about a mile in length, with
insulators, is run parallel to a high power line that a "one-turn transformer" can be created, inductively coupling some of the power of the high-power
lines.
END
Now think of this as brainstorming on my part, Remember the magnets on first and second device, and Marco or Dave spotted the very fine wire on the bottom ring of second device. We cannot see any real fine wires on the first prototype, because it maybe in the centre of the thing, right below that toroidal inductor.
Also look at the larger device, with those fine wires on the small toroids....see what im getting at.......receptors.....detectors
First we have to find the river, then we can work out how to extract the energy.
My first step, because this part has been bothering me, until, I read the above.
Good work everyone, keep at it
Dom    :)
