The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
Mr_Video
it is NOT the patent for the TPU
it's the Martinez "Continuious Electric Generator"
which I have seen on the net before
sorry guys :(
mikestocks2006
Quote from: mrd10 on November 04, 2006, 07:18:09 AM
Dave, what SM is getting at is, that there is an interaction between the earths magnetic field and when we first apply current into a wire.
So its a river we can't see, all we want to do is know how to tap into it. Going back to What SM says:-
Now I am you know that anytime you have a magnetic field moving past a wire you have electron flow in that wire or more precisely on the surface.
So the earth is generating the most unbelievably huge amount of power all the time and we can't tap into it?! I don't believe it!  Neither did Nicola Tesla.
He found a way to tap into the earth's power potential and he demonstrated it often.
Did you know that every single one of his patents was purchased by Edison and Westinghouse? He had a very large amount of patents and they purchased all of them but only utilized one for transmitting electric power via 60 cycle AC and step down transformers, which became the standard of power transmission throughout the earth to this day.
Anyway, back to his research in the laboratory. He noticed that most of the time the magnetometers stayed relatively sedate and around the same level. They would fluctuate just slightly. however one day he noticed that the meters jumped quite unpredictably.  It attracted his attention and he began to find that the meters were reacting to a thunderstorm many hundreds of miles away. Interesting isn't it?
Then he continued his experiments and found that as a thunderstorm moved closer the magnetometers would register larger and larger fluctuations until they were off the scale and useless.
He was fascinated and consumed by this. He acquired better magnetometers and his research found that you could tune the magnetometers to certain specific frequencies and tap directly into large magnetic waves. When I say large, I am referring to huge. That was useable power.
However, you had to find a circuit potential in order for the electrons to flow. That was the difficulty which he overcame to produce his famous demonstrations of power from nowhere.
Please let me make another point.
Let us say that you have a magnetic field perhaps it is only a small permanent magnet. Now, you have a single copper wire twelve inches long. If you move the magnet across the surface of the wire from left to right at a certain speed you create an electron flow which is DC and it has a power potential based on how strong the field is and how fast the magnet if moved. So, if you increase the size of the magnet or the speed it moves you create a larger flow of electrons, larger as in higher voltage or more currant.
Everyone tells us that the earth's magnetic field is measured as being too insignificant to generate any useable power, that is not so.
Let me give you something to think about...  If you had a short wire and you moved a magnet across it you would always have limited potential because the length of wire was so short. OK now what if we increase the length of the wire to many miles in length even with a very weak magnetic field moving across the wire you still have a much greater potential flow of power available.  If we put it into a perspective of power per inch it may be easier to understand.
If you have a small magnetic field moving across a wire twelve inches long it can generate an electron flow equal to lets say one millivolt per inch. If you move the magnet twelve inches at the same speed you get 12 millivolts as you transgress the twelve inches of wire. Understand that I am trying to convey a principal that you can understand for use in the future.
So, you have a wire twelve inches long and you can make 12 millivolts moving a magnet across it. If you have a wire 1000 feet long and you move the same small magnetic field across the length of it you can create much more voltage potential perhaps 12,000 millivolts lets say.
So, you have managed to generate a significant amount of electric power with a weak magnetic force.
OK, how does this help us? where am I going with this?
Suppose you have 1,000 pieces of wire twelve inches long and you run the same weak magnetic field over them all at the same time..... you get the same flow of electrons.
If the wires are run in series then you will get the 12,000 millivolts etc. If you connect the wires in parallel you will get higher current but lower voltage.  However, the power potential is the same whether you run the wires in series or parallel.
If you know how to find the circuit potential, you tune into the frequency and you have enough short pieces of wire you can convert as much power as you wish in a given space.
Things are more complex then what I have told you but I am just trying to give you an idea of how the technology works.
How it IS POSSIBLE to use what appears to be a weak magnetic force to generate large useable amounts of power.
Nice, that and Dave's questioning of where does the energy come from.!
I keep thinking where is the input?. The device is passive, the device is passive. Tesla did not have the power supplies, sine, square wave generators we have today. SM?s device is passive, no external power supplies.
Ok this maybe easier than we think! And it is a TOROID to boot.
Take a look at this.
It creates a field (blue lines) to invoke a response from the coin, the coin in return creates its own field (red lines) sending a response back to the coil. The coil reads the field and produces a signal. So far so good!
Now an energy input is required from the unit to create the original pulse to hit the coin and thus the requirement for external power supply (battery)
But that is only because the coin it self is not sending out anything.
Bingo!
Replace the coin with the earth. No need for external power supply to excite the earth. The earth field already pulsates even if it is weak, it pulsates (red lines). Tune the coil to that pulse and you got a passive signal generation (and thus power) with no outside power supply.
On top of that, I?m looking at all the writings. DC output. Makes sense the earth field is not reversing it just fluctuates in one direction, thus inducing a DC fluctuating current on the coil. There is no need for a full reversing wave to get amplification it doesn?t have to go negative. Fluctuations in the positive region will also do the trick.
Maybe a closer look into how these gadgets work would provide a better starting point to built on?
Does the above make sense or have I missed something major by a mile?
Take a look at this. http://micro.magnet.fsu.edu/electromag/java/detector/
Mr_Video
giantkiller
Quote from: dean_mcgowan on November 04, 2006, 05:23:57 AM
isnt this supposed to be pulsed dc we are creating here ..
Yes. Many have posted the the findings of kicks. The best results have come the + / - square waves. I work on pinball machines. Every coil has a diode across it to dump the kick to ground to alleviate from damaging other components. Let's drop the creation of kicks issue and move on. They exist and we can create them. At what instance of time? We covered that before too with the tranmission wave analysis on the calulated ring diameter with the tranmission frequency with the matching the collector to that. I agree it is a rough set of specs. But we know the wheels are round, so let's slap them on the sports car and get the hell outta Dodge!
We produce the kicks. We harmonize them at the ring perimeter over the collector / antennae.
Marco and I also posted how the rings actually sit in the application over the Earth and what the fields look like. More to think about.
On a similar note,
There is an old Twilight Zone issue called 'Kick the can'. A group of elderly patients at a rest home believe they can have fun playing on the lawn. One resident refuses to believe and stays on the porch. The others play joyfully, regain their youth and run off as young children. The elderly one, left behind, sits and wonders what went wrong. If you don't believe this story has any benefit, you're still on the porch.
Please, prove me wrong.
--giantkiller. ;)
giantkiller
Quote from: mikestocks2006 on November 04, 2006, 11:49:05 AM
Yep. You're right on bud! That it flow of the giantkiller/marco overlays posted a while back. Just re-emphasizing your stronger post. Keep swimming, Keep swimming! (quote by Dorie from Nemo movie).
--giantkiller
